7i92+7i77 Not connect
15 Jul 2022 14:40 #247386 by SOLD
Replied by SOLD on topic 7i92+7i77 Not connect
So you are saying that the encoders behave differently on the old 7I92 and the new 7I92
when you do _nothing_ but swap 7I92 cards?
Yes, the encoder works differently on the old 7I92 and the new 7I92 .
When switching the 7I92 card
The old 7i92 works fine.
15 Jul 2022 14:46 #247387 by SOLD
This time I use the ./mesaflash --device 7i92 --addr10.10.10.10 --write 7i92_fallback.bit
Error: BootSector is invalid
But
it ok.
15 Jul 2022 14:53 #247388 by PCW
Replied by PCW on topic 7i92+7i77 Not connect
1. Sounds like you have 2 mesaflash versions installed on your system
I would install the latest (3.4.3)
2. Why would you write the fallback configuration?
15 Jul 2022 15:14 #247389 by SOLD
I installed 3.4.3 but the old version is still there. I don't know how to remove
15 Jul 2022 15:28 #247392 by PCW
running "mesaflash" will run the installed version (in the execute path)
running "./mesaflash" runs the mesaflash version in the current directory
If you install mesaflash with "sudo make install" you should always use "mesaflash"
15 Jul 2022 16:09 #247398 by SOLD
when i use mesaflash I can't use --version, --dbname
15 Jul 2022 16:13 #247399 by PCW
That means you did not install the latest mesaflash
(with "sudo make install")
The following user(s) said Thank You: SOLD
18 Jul 2022 14:18 - 18 Jul 2022 14:25 #247674 by SOLD
โพสต์ PCW=247399 userid=481นั่นหมายความว่าคุณไม่ได้ติดตั้ง mesaflash ล่าสุด
(ด้วย "sudo make install")
I installed debian linuxcnc 2.8 with Mesaflash3.4.3 on a new computer. Mesaflash 3.4.3 works.
when i install the firmware 7i92_7i77x2.bit succeeded, but still unable to connect to 7i77.
- flash memory sector to write:6 max sectors in area:16
- Flash memory sectors start from 0x1000000, is that correct?
-Is there any way to initiate a new firmware installation?
Last edit: 18 Jul 2022 14:25 by SOLD.
18 Jul 2022 14:36 #247682 by PCW
Sounds like the firmware is OK, but you can verify the pinout with
mesaflash --device 7i92 --addr 10.10.10.10 --dbname1 7i77
The non-functioning serial I/O and encoder sound like bad 7I92 outputs
(the TX pins and encoder mux pin seem to be non-functional)
18 Jul 2022 14:43 #247685 by SOLD
โพสต์ PCW=247682 userid=481ดูเหมือนว่าเฟิร์มแวร์จะใช้ได้ แต่คุณสามารถตรวจสอบพินเอาต์ด้วย
I/O อนุกรมที่ไม่ทำงานและตัวเข้ารหัสมีเสียงเหมือนเอาต์พุต 7I92 ที่ไม่ดี
(พิน TX และตัวเข้ารหัส ดูเหมือนว่า mux pin จะใช้งานไม่ได้)
Is it damaged at 16211AE or not?
Can you suggest me a preliminary check?
Moderators: PCW, jmelson
