Mesa Confguration Tool Update
- HansU
- Thank you received: 217
12 Nov 2022 18:41 - 12 Nov 2022 18:46 #256520
by HansU
Replied by HansU on topic Mesa Confguration Tool Update
Yeah that works now.
But can't you add another "cardType"?
'7i85': 'servo'
Because the 7i85 is neither 'servo' nor 'step'. Just an encoder/communication interface.
And why do you commit the deb packages to the repo? It just increases the size of the repo and takes long time to pull. Isn't it enough to put them in the releases section?
Last edit: 12 Nov 2022 18:46 by HansU.
- JT
- Thank you received: 595
13 Nov 2022 22:01 - 13 Nov 2022 22:02 #256614
by JT
Replied by JT on topic Mesa Confguration Tool Update
Right now I have two choices stepper and servo, maybe I should drop the 7i85?
I'd have to figure out how to download from the releases section and how to sort out the three different debs... any clues?
Also I make several debs during one release so I need to be able to update them...
JT
JT
Last edit: 13 Nov 2022 22:02 by JT.
- HansU
13 Nov 2022 22:21 #256618
by HansU
Just attach them when you create a release. Or click on edit and add them later.
Would look like this: github.com/hansu/mesact/releases
Yes, maybe it isn't worth to add a new type for this rarely used card.Right now I have two choices stepper and servo, maybe I should drop the 7i85?
- JT
14 Nov 2022 23:03 #256740
by JT
I've moved all the old debs into the releases section but I have to leave the latest one so the download button still works on previous releases. The current download button does download from the latest release.
JT
JT
The following user(s) said Thank You: tommylight, HansU
Time to create page: 0.095 seconds
