Mesa hm2/hm2_7i96s.0: error finishing read
2 years 11 months ago #285921 by spumco
The errors are happening so fast I cant get halscope open and set up before the error happens.
Tried setting error limit to 1000 and it's essentially immediate.
I found that I can get halscope to auto-start with 'loadusr' in hal file, but not sure how to call up a particular halscope file or get the pins set to capture everything immediately.
2 years 11 months ago - 2 years 11 months ago #285929 by spumco
Managed to catch it.  This with error-level set to 1000.
Does not appear to be intermittent errors piling up, but a failure to commuicate from the start?
EDIT
Set error-level to 10000 and exactly the same thing happened, just took longer to trigger.
This feels like some sort of setting I've got wrong and not some intermittent communications error.
Last edit: 2 years 11 months ago by spumco. Reason: more info
2 years 11 months ago - 2 years 11 months ago #285933 by PCW
Yes, that looks like it simple times out every packet
(so about 1/2 second to get the 500 time out errors needed to trip the read error)
Maybe is is worth looking into the configuration a bit,
Can you try a minimal configuration? (nothing but axis stepgens for example)
Last edit: 2 years 11 months ago by PCW.
2 years 11 months ago #285945 by spumco
Slight change with minimal config - errors stop briefly, then accumulate again.
Entire HAL file is in upper left of screenshot.
2 years 11 months ago - 2 years 11 months ago #285946 by PCW
Looks like the interface dropped the link entirely...
Does the Yellow LED on the 7I96S RJ45 blink out ever?
2 years 11 months ago #285947 by spumco
Still thinking it's a setting? Or hardware?
The same behavior repeats every time.
Moderators: PCW, jmelson
Time to create page: 0.345 seconds
