Mesa hm2/hm2_7i96s.0: error finishing read
2 years 11 months ago - 2 years 11 months ago #285948 by spumco
[7i96 is in back of the machine, so I have to start LCNC and run around to watch...]
Yellow LED stayed lit.
Reds were on (from previous read error?)
Reds went out, green ones blinked sequence then solid
Greens went out, reds lit (assuming when it errored, can't watch screen at same time)
Reds went out again, greens sequenced
Green went out, red lit and stayed lit
EDIT
Sorry, though you meant the yellow board LED.
Yes, the RJ45 yellow LED goes out and them comes back on.
Last edit: 2 years 11 months ago by spumco. Reason: more info
2 years 11 months ago #285950 by spumco
Just video'd the sequence.  Sorry if the description is clunky, can't post a vid.
(START)
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - ON
RJ45 Yel - ON
CR8 - ON
CR7 - ON
CR6 - off
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - ON
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - ON
CR6 - off
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - sequence then off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - ON
RJ45 Yel - ON
Repeats
2 years 11 months ago #285955 by PCW
OK I apologize as I was not clear with my red LED comments
If CR7 (/DONE) ever illuminates after power up, there is likely a 5V power issue
(CR6 lighting up after power up indicates a watchdog bite)
2 years 11 months ago #285961 by spumco
Well...
It appears the 7i96s doesnt like buck converters, but it seems OK with field-expedient cheapo USB wall wart and chopped up USB cable.
It's been running for 10 minutes without a single packet error, much less a read finishing tantrum.
I might have another go with the G2 in a little while.
2 years 11 months ago #285964 by tommylight
2 years 11 months ago #285967 by spumco
It was only 3 days misery.
Getting the Odroid sorted out last year was 3 or 4 months. image missing /media/kunena/emoticons/wink.png
Moderators: PCW, jmelson
Time to create page: 0.483 seconds
