Mesa hm2/hm2_7i96s.0: error finishing read
2 years 11 months ago #285699 by rodw
This is an old document I did up but the principles are still the same except use ANdy's script in the 2.9 getting linuxcnc docs to instal llinuscmc
This solved the Realtek NIC issues for a lot of guys.
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
2 years 11 months ago #285713 by tommylight
Now I'm getting errors trying to remove the driver.
How and from where did you install this version?
It is an older version of Debian 12 with some issues, namely looking for raspi stuff on an AMD build!
You can fix it by searching for "raspi" and deleting all 3 files it finds, then update and upgrade as usual.
2 years 11 months ago #285735 by spumco
What command did you run? It does not show.
sudo apt purge r8168-dkms
2 years 11 months ago #285736 by spumco
Got it from the main downloads page on linuxcnc.com
2 years 11 months ago #285737 by spumco
I'll have another go using the doc Rod linked this evening.
Failing that, the next PC to try out should be here Monday.
2 years 11 months ago #285742 by chris@cnc
Hello, I'm also trying something on this topic. I have the 6.6. kernel not built with the Debian standard configuration. I don't have a Realtek card to test with. If you want, you can try out this kernel. I'm curious to see if he has improved with realtek.
drive.google.com/drive/folders/1HceAcPQd...u4zS9?usp=drive_link
Moderators: PCW, jmelson
Time to create page: 0.388 seconds
