- Thank you received: 5334
I had major issues with this exact Elitedesk setup recently that I made a post about in my build thread here on the forum: forum.linuxcnc.org/12-milling/50559-opti...nc-conversion#284497[Rather than starting a new thread, I'll continue here...]
Starting to commission a new build and I'm getting the error finishing read problem crop up within seconds of starting LCNC and could use some help diagnosing.
PC: HP elitedesk 800 G2 mini
NIC: Intel i219LM
LCNC: 2.9 from ISO on LCNC home page
Kernel: 6.1.0-13 (haven't messed with this)
etc/network/interfaces:
auto lo
iface lo inet loopback
auto eno1
iface eno1 inet static
address 10.10.10.1
hardware-irq-coalesce-rx-usecs 0
Grub:
isolcpus=3 intel_pstate=disable processor.max_cstate=0 idle=poll cpufreq.default_governor=performance i915.enable_dc=0 ahci.mobile_lpm_policy=1 irqaffinity=0 nomodeset quiet
Good latency after fiddling with grub. Just copied the above from the latency thread, don't really understand the backstage stuff.
LCNC terminal output:
Warning: Spoiler!athe@lathe:~$ linuxcnc
LINUXCNC - 2.9.1
/usr/bin/linuxcnc: line 338: cd: $'/home/lathe/linuxcnc/configs\n.\n2)': No such file or directory
Machine configuration directory is '/home/lathe/linuxcnc/configs/LATHE_REV0 (DAY 2)'
Machine configuration file is 'LATHE_REV0.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
twopass:invoked with <> options
twopass:found ./01MAIN.hal
twopass:found ./02IO.hal
twopass:found ./03SPINDLE.hal
twopass:found ./04CONSOLE.hal
twopass:pass0: loadusr -W hal_manualtoolchange
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:84:f0
hm2_eth: discovered 7I96S
hm2/hm2_7i96s.0: Low Level init 0.15
hm2/hm2_7i96s.0: Smart Serial Firmware Version 43
Board hm2_7i96s.0.7i84.0.0 Hardware Mode 0 = standard
Board hm2_7i96s.0.7i84.0.0 Software Mode 0 = input_output
Board hm2_7i96s.0.7i84.0.0 Software Mode 1 = io_analog_fieldvoltage
Board hm2_7i96s.0.7i84.0.0 Software Mode 2 = io_encoder_analog
Board hm2_7i96s.0.7i73.0.1 Hardware Mode 0 = nokeyboardnodisplay
Board hm2_7i96s.0.7i73.0.1 Software Mode 0 = inputoutputencoder
Board hm2_7i96s.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalog
Board hm2_7i96s.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalog
Board hm2_7i96s.0.7i73.0.1 Hardware Mode 1 = nokeyboarddisplay
Board hm2_7i96s.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplay
Board hm2_7i96s.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplay
Board hm2_7i96s.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplay
Board hm2_7i96s.0.7i73.0.1 Hardware Mode 2 = keyboard4by8nodisplay
Board hm2_7i96s.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode4by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode4by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode4by8
Board hm2_7i96s.0.7i73.0.1 Hardware Mode 3 = keyboard4by8display
Board hm2_7i96s.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode4by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode4by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode4by8
Board hm2_7i96s.0.7i73.0.1 Hardware Mode 4 = keyboard8by8nodisplay
Board hm2_7i96s.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode8by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode8by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode8by8
Board hm2_7i96s.0.7i73.0.1 Hardware Mode 5 = keyboard8by8display
Board hm2_7i96s.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode8by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode8by8
Board hm2_7i96s.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode8by8
hm2/hm2_7i96s.0: 51 I/O Pins used:
hm2/hm2_7i96s.0: IO Pin 000 (TB3-01): InM Input Module #0, pin in0 (Input)
hm2/hm2_7i96s.0: IO Pin 001 (TB3-02): InM Input Module #0, pin in1 (Input)
hm2/hm2_7i96s.0: IO Pin 002 (TB3-03): InM Input Module #0, pin in2 (Input)
hm2/hm2_7i96s.0: IO Pin 003 (TB3-04): InM Input Module #0, pin in3 (Input)
hm2/hm2_7i96s.0: IO Pin 004 (TB3-05): InM Input Module #0, pin in4 (Input)
hm2/hm2_7i96s.0: IO Pin 005 (TB3-06): InM Input Module #0, pin in5 (Input)
hm2/hm2_7i96s.0: IO Pin 006 (TB3-07): InM Input Module #0, pin in6 (Input)
hm2/hm2_7i96s.0: IO Pin 007 (TB3-08): InM Input Module #0, pin in7 (Input)
hm2/hm2_7i96s.0: IO Pin 008 (TB3-09): InM Input Module #0, pin in8 (Input)
hm2/hm2_7i96s.0: IO Pin 009 (TB3-10): InM Input Module #0, pin in9 (Input)
hm2/hm2_7i96s.0: IO Pin 010 (TB3-11): InM Input Module #0, pin in10 (Input)
hm2/hm2_7i96s.0: IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96s.0: IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96s.0: IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96s.0: IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96s.0: IO Pin 015 (TB3-21/TB3-22): OutM Output Module #0, pin Out-04 (Output)
hm2/hm2_7i96s.0: IO Pin 016 (TB3-23/TB3-24): OutM Output Module #0, pin Out-05 (Output)
hm2/hm2_7i96s.0: IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 025 (TB2-02/TB2-03): StepGen #4, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 026 (TB2-04/TB2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 027 (TB2-07/TB2-08): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i96s.0: IO Pin 028 (TB2-10/TB2-11): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i96s.0: IO Pin 029 (TB2-13/TB2-14): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i96s.0: IO Pin 030 (TB2-16/TB2-17): Smart Serial Interface #0, pin rx0 (Input)
hm2/hm2_7i96s.0: IO Pin 031 (TB2-18/TB2-19): Smart Serial Interface #0, pin tx0 (Output)
hm2/hm2_7i96s.0: IO Pin 032 (internal): Smart Serial Interface #0, pin txen0 (Output)
hm2/hm2_7i96s.0: IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96s.0: IO Pin 034 (P1-01/DB25-01): Smart Serial Interface #0, pin rx1 (Input)
hm2/hm2_7i96s.0: IO Pin 035 (P1-02/DB25-14): Smart Serial Interface #0, pin tx1 (Output)
hm2/hm2_7i96s.0: IO Pin 036 (P1-03/DB25-02): StepGen #8, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 037 (P1-04/DB25-15): StepGen #8, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 038 (P1-05/DB25-03): StepGen #7, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 039 (P1-06/DB25-16): StepGen #7, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 040 (P1-07/DB25-04): StepGen #6, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 041 (P1-08/DB25-17): StepGen #6, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 042 (P1-09/DB25-05): StepGen #5, pin Step (Output)
hm2/hm2_7i96s.0: IO Pin 043 (P1-11/DB25-06): StepGen #5, pin Direction (Output)
hm2/hm2_7i96s.0: IO Pin 044 (P1-13/DB25-07): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i96s.0: IO Pin 045 (P1-15/DB25-08): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i96s.0: IO Pin 046 (P1-17/DB25-09): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i96s.0: IO Pin 047 (P1-19/DB25-10): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i96s.0: IO Pin 048 (P1-21/DB25-11): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i96s.0: IO Pin 049 (P1-23/DB25-12): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i96s.0: IO Pin 050 (P1-25/DB25-13): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i96s.0: registered
creating ladder-state
note: MAXV max: 0.500 units/sec 30.000 units/min
note: LJOG max: 0.500 units/sec 30.000 units/min
note: LJOG default: 0.500 units/sec 30.000 units/min
note: jog_order='ZX'
note: jog_invert=set()
hm2/hm2_7i96s.0: error finishing read! iter=4596
Ping times
Warning: Spoiler!lathe@lathe:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.214 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.121 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.120 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.121 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.120 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.120 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.121 ms
64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.122 ms
64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=0.120 ms
64 bytes from 10.10.10.10: icmp_seq=10 ttl=64 time=0.120 ms
^C
--- 10.10.10.10 ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9215ms
rtt min/avg/max/mdev = 0.120/0.129/0.214/0.028 ms
Would trying a later kernel (6.3,6.4,etc.) help? I did see mention elsewhere here that there is a recently fixed bug related to Intel i219LM NICs...but don't know if that's related or when the fix will make it to kernels appropriate for LCNC.
ThxI
