Mesa hm2/hm2_7i96s.0: error finishing read
  • JT
  • JT's Avatar Topic Author
  • Administrator
  • Administrator
11 Jan 2023 13:37 #261560 by JT
Odd looking in Synaptic I have linux-image-6.1.0-rt5-liuxcnc-rt installed but don't see any header for 6.1...
JT
11 Jan 2023 20:52 #261618 by rodw
No John sorry. Those settings allow building the debs without security keys.
You should be able to use the same method to set the fully preeptible kernel setting which would allow a fully scripted solution to build the kernel :)
What is solving is it is that by using the pristine kernel.org upstream source, the buggy RT kernel patches applied by Debian are bypassed. I've shared the location of these patches previously. Lazy preemption is my top candidate
I have wondered if you could pull down the RT patch source from debian and use the debian system to rebuild linux-image-rt without some f these patches.
But its good you brought this to the top as I think I've found something useful. See if you can enable CONFIG_NET_RX_BUSY_POLL in the kernel and rebuild it. Then when running that kernel try typing:
sudo sysctl -w net.core.busy_poll=50
sudo sysctl -w net.core.busy_read=50
This enables polling instead of interrupts on the network which results in lower latency at the expense of higher CPU utilisation and prevents the PC to sleep. There are a few references but this one is fairly authoritive
caxapa.ru/thumbs/793343/Open_Source_Kern...cements_for_Low-.pdf
A setting of 50 is recommended by redhat for a few sockets.
PCW, I'm not sure yet if this requires changes to the socket used by hm2_eth to add the SO_BUSY_POLL socket option to the socket.
11 Jan 2023 21:04 #261621 by rodw
So the Debian patches are here:
salsa.debian.org/kernel-team/linux/-/tre...er/debian/patches-rt
If you read the file series, it explains whats going on and the orderpatches are applied.
You would need to compare the differences between the buster branch and master branch to find whats changed
But the number of patches in Buster are massive and have slowly been reducing as the real time patches are incorporated into the main line over time.
11 Jan 2023 21:12 - 11 Jan 2023 21:15 #261623 by PCW
I think busy polling requires driver support which does not seem to be present
for common MACs
That said, the stock 6.x kernel seems OK as-is for Intel MACs
(I have about a month of uptime now without any "error finishing read"s)
Does the Driver change fix the Realtek issue?
Last edit: 11 Jan 2023 21:15 by PCW.
11 Jan 2023 21:31 #261631 by rodw
Peter, this is all conjecture right now as I only just got this far.
I am not sure if the low latency busy_poll/busy_read settings enable low latency for all NIC's or just specific sockets that request it.
Some of the docs always referred to sockets needing to be enabled and that implied the underlying connection (in hm2_eth) to me.
Nowhere does it actually refer to using this on a specific NIC, just sockets.
11 Jan 2023 21:39 - 11 Jan 2023 21:40 #261633 by rodw
Damn! The intel doc refers to a specific NIC as a requirement so a dead end :(
From the debian source, it would be interesting to build the debian RT image without including these patches
# Lazy preemption
sched__Add_support_for_lazy_preemption.patch
x86_entry__Use_should_resched_in_idtentry_exit_cond_resched.patch
x86__Support_for_lazy_preemption.patch
entry--Fix-the-preempt-lazy-fallout.patch
arm__Add_support_for_lazy_preemption.patch
powerpc__Add_support_for_lazy_preemption.patch
arch_arm64__Add_lazy_preempt_support.patch
Last edit: 11 Jan 2023 21:40 by rodw.
  • JT
  • Administrator
  • Administrator
07 Feb 2023 12:05 #263919 by JT
I got an Intel PCIe NIC in a pc running for a week now and I did get one error finishing read but that might have been the PC getting a power blink during an winter weather event.
www.amazon.com/dp/B001CY0P7G
JT
11 Feb 2023 16:49 - 11 Feb 2023 16:51 #264295 by chris@cnc
Replied by chris@cnc on topic Mesa hm2/hm2_7i96s.0: error finishing read
I also try to upgrade my system and had some trouble with this latency. The best result I got with following configuration. Any Idea how to get better. The latency on my old 4.19. kernel was less the half. But at the moment still no error anymore.
lsb_release -d
Description:    Debian GNU/Linux bookworm/sid
uname -a
Linux cnc 6.1.0-3-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.8-1 (2023-01-29) x86_64 GNU/Linux
cat /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet idle=poll isolcpus=2,3"
halcmd show param hm2*tmax
Owner   Type  Dir         Value  Name
    36  s32   RW        1207088  hm2_7i76e.0.read.tmax
    36  s32   RW         376428  hm2_7i76e.0.write.tmax
    30  s32   RW        1440491  servo-thread.tmax
lspci |grep Ethernet
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (5) I219-LM
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
system info in file
sudo lshw -short > lshw.txt
Last edit: 11 Feb 2023 16:51 by chris@cnc.
11 Feb 2023 23:14 #264327 by rodw
I would stop there if the problem is gone away. Be sure to use your intel card to talk to mesa.
As an aside, I went to an Ethercat seminar held in Australia on Friday. Beckhoff said they use intel NIC's exclusively  in their devices.
It was interesting to apply the differences between ethercat and other fieldbus systems to our own problem as ethercat is muc more efficient.
I've been pondering if the hm2eth driver and mesa card could use a custom protocol (eg no ip addresses) to avoid the overhead from the layered  TCP transport mechanism. But I'm not the one to do that!
Conceptually, this does not seem hard to do as its normal to only have one mesa card on the etheret connection so let it be a slave and hm2 be the master.
I can't see this problem will go away in later kernels.
11 Feb 2023 23:29 - 11 Feb 2023 23:30 #264331 by PCW
I expect the problem to improve as there has a considerable improvement with 6.1/6.2
kernels over 5X. Whether Realtek will fix their drivers is another issue. Intel seem more interested in real time.
Note that TCP is not used by hm2_eth (nor are IP addresses after the host determines
the target MAC address)
Last edit: 11 Feb 2023 23:30 by PCW.
Moderators: PCW, jmelson
Time to create page: 0.224 seconds
