Mesa hm2/hm2_7i96s.0: error finishing read
- Thank you received: 5326
09 Dec 2022 18:42 #259029
Replied by PCW on topic Mesa hm2/hm2_7i96s.0: error finishing read
What ping times do you get?
- JT
- Thank you received: 593
09 Dec 2022 20:52 #259042
by JT
I'll run ping for a while and see what I get...
JT
Replied by JT on topic Mesa hm2/hm2_7i96s.0: error finishing read
14 packets transmitted, 14 received, 0% packet loss, time 13296ms
rtt min/avg/max/mdev = 0.078/0.083/0.116/0.009 msI'll run ping for a while and see what I get...
JT
- JT
09 Dec 2022 23:13 #259049
by JT
A longer run
JT
8195 packets transmitted, 8195 received, 0% packet loss, time 8390659ms
rtt min/avg/max/mdev = 0.061/0.083/0.407/0.015 msJT
- Online
- Thank you received: 4149
09 Dec 2022 23:33 #259050
Replied by rodw on topic Mesa hm2/hm2_7i96s.0: error finishing read
There must be more at work here than just Ping times. John's are very good.
I've got a J1900 here with Realtek drivers that has worse ping time yet has not triggered an error finishing read on overnight runs. Matter of fact I'm going to install it back on a machine that is having dramas with a similar PC. Running Bookworm and the 6.0 kernel. Thats bound to cause it to error!
INteresting though This machine generated unusable latency with the internal wifi card connected back on Mint 17.3 with a compiled RT kernel. Now the Wifi is as good as gold. So there has been som eimprovement with the kernel...
- JT
10 Dec 2022 11:09 #259078
by JT
Did you see the max?
JT
JT
- Online
10 Dec 2022 11:21 #259080
Around 800k
- JT
10 Dec 2022 16:31 #259105
by JT
JT
Did you see my max time?0.407There must be more at work here than just Ping times. John's are very good.
JT
- Online
10 Dec 2022 21:02 #259135
overnight no errors . Since your longer run anyway
Ping times
max ping time = 0.510
Ahh, on this PC, the change to the driver actually stuckSomething odd happened as the driver was rebuilt when I changes linux-headers, not when I installed the driver.
Then it worked...
PS. not playing with this one anymore!
packing@packing:~$ halcmd show param hm2*tmax*
Parameters:
Owner Type Dir Value Name
93 s32 RW 0 hm2_7i76e.0.read-request.tmax
93 bit RO FALSE hm2_7i76e.0.read-request.tmax-increased
93 s32 RW 909760 hm2_7i76e.0.read.tmax
93 bit RO FALSE hm2_7i76e.0.read.tmax-increased
93 s32 RW 489900 hm2_7i76e.0.write.tmax
93 bit RO FALSE hm2_7i76e.0.write.tmax-increased
Ping times
64 bytes from 10.10.10.10: icmp_seq=19 ttl=64 time=0.455 ms
64 bytes from 10.10.10.10: icmp_seq=20 ttl=64 time=0.425 ms
64 bytes from 10.10.10.10: icmp_seq=21 ttl=64 time=0.434 ms
64 bytes from 10.10.10.10: icmp_seq=22 ttl=64 time=0.498 ms
64 bytes from 10.10.10.10: icmp_seq=23 ttl=64 time=0.500 ms
64 bytes from 10.10.10.10: icmp_seq=24 ttl=64 time=0.510 ms
64 bytes from 10.10.10.10: icmp_seq=25 ttl=64 time=0.465 ms
^C
--- 10.10.10.10 ping statistics ---
25 packets transmitted, 25 received, 0% packet loss, time 24366ms
rtt min/avg/max/mdev = 0.245/0.465/0.698/0.074 ms
packing@packing:~$ max ping time = 0.510
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
packing@packing:~$ sudo ethtool -i enp3s0
driver: r8168
version: 8.050.03-NAPIThen it worked...
- Thank you received: 7481
10 Dec 2022 21:55 #259136
Usually the first one or two replies are longer, then settle.
min/ avg/ max/ mdev
Replied by tommylight on topic Mesa hm2/hm2_7i96s.0: error finishing read
Nope, max ping time 0.698.rtt min/avg/max/mdev = 0.245/0.465/0.698/0.074 ms
min/ avg/ max/ mdev
10 Dec 2022 21:56 #259137
Cr@p, it broke the formating!
Time to create page: 1.442 seconds
