wiring MPGs to 7i96s
- Masiwood123
- Thank you received: 93
26 Sep 2022 12:57 - 26 Sep 2022 13:03 #252760
by Masiwood123
wiring MPGs to 7i96s was created by Masiwood123
Last edit: 26 Sep 2022 13:03 by Masiwood123.
- Thank you received: 5330
26 Sep 2022 14:40 #252769
Replied by PCW on topic wiring MPGs to 7i96s
MPG1-A 7I96S IN0
MPG1-B 7I96S IN1
MPG2-A 7I96S IN2
MPG2-B 7I96S IN3
GND 7I96 IN COMMON
This does mean the other 7I96S inputs are sinking inputs
(pull high to activate)
MPG1-B 7I96S IN1
MPG2-A 7I96S IN2
MPG2-B 7I96S IN3
GND 7I96 IN COMMON
The following user(s) said Thank You: Masiwood123
- Masiwood123
26 Sep 2022 14:58 #252772
by Masiwood123
Replied by Masiwood123 on topic wiring MPGs to 7i96s
If this is correct, then I understand, I tried to search the forum for some Hal examples of assigning functions to inputs for MPG, but it confuses me, considering that the axis selector is used almost everywhere, I don't need mpg for positioning, more for manual synchronized work of the x and z axes. Do you have an example of how it should be added to Hal, because in pnccnfg and not even in mesact, as far as I've seen, there is no input allocation , assign for MPG?
26 Sep 2022 15:35 #252777
You would need to connect:
hm2_7i96s.0.inm.00.enc0-count
hm2_7i96s.0.inm.00.enc1-count
to the appropriate axis jog-counts pins
- Masiwood123
26 Sep 2022 16:30 #252784
by Masiwood123
linuxcnc.org/docs/devel/html/examples/mpg.html
do i need to include all this in the config including ilowpass, mux4(what is that), scale..etc
26 Sep 2022 17:34 #252790
Yes, the only thing different is the source pin of the counts
- HansU
- Thank you received: 217
26 Sep 2022 17:42 #252791
by HansU
If you want to switch between different scalings of the MPG, or want to use one MPG for different axes, then yes.
Ilowpass you may need in every case for smoother jogging.
Replied by HansU on topic wiring MPGs to 7i96s
- Masiwood123
26 Sep 2022 18:38 #252794
by Masiwood123
I would like the x encoder to follow jog velocity which is set in gui(not with increments 0.1,10,100,(physical selector) Z axis the same that.. also i dont need it for positioning, want it too works always(I mean while gcode not in progress).. also I would like both axes to work at the same time also I don't need any selector. I will have some frequent small operations on the lathe I am making and I would like to be able to do it manually, not via gcode, what else do I want I give a child or an old father to play with the hands and make something (those who don't know what a volt or watt is, and haven't even heard of gcode yet:)))Thank you all
- Masiwood123
26 Sep 2022 18:47 #252795
by Masiwood123
something like this
something like this
- HansU
28 Sep 2022 12:52 #252933
by HansU
Then you don't need most of these examples. You only have to connect your pins
to
And set theses pins:
axis.x.jog-enable
axis.z.jog-enable
And set a scale:
axis.x.jog-scale
axis.z.jog-scale
But I would recommend to use the ilowpass for smoother jogging like in the second example. But you need two instances of that component.
hm2_7i96s.0.inm.00.enc1-countto
axis.x.jog-counts
axis.z.jog-countsAnd set theses pins:
axis.x.jog-enable
axis.z.jog-enable
And set a scale:
axis.x.jog-scale
axis.z.jog-scale
Time to create page: 0.357 seconds
