wiring MPGs to 7i96s
  • Masiwood123
  • Masiwood123's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Oct 2022 23:48 #254482 by Masiwood123
Replied by Masiwood123 on topic wiring MPGs to 7i96s
hahhaaa you know that's it! I don't remember when, but that's exactly how it was, like many other things from childhood that are pointless, but missing..
I'm as happy as a child with this wheels playing:))
The following user(s) said Thank You: arvidb, tommylight
  • Moderator
  • Moderator
19 Oct 2022 00:35 #254484 by tommylight
Replied by tommylight on topic wiring MPGs to 7i96s
I'm as happy as a child with this wheels playing :) )
Exactly! :)
Last night i made the tool changer on the Mazak work, MPG works,and figured out all the sensors from the tool changer, so i went home very happy.
I was worried that will give me trouble...
  • Masiwood123
  • Platinum Member
  • Platinum Member
19 Oct 2022 12:59 #254518 by Masiwood123
we are all night birds, it works best when no one is around;) that's very fucked up, especially since you don't have a wiring manual...that quality of machine is no longer made, and it's even more satisfying when it comes to life. btw, regarding rats, i found cables made almost from old machines in the US ,all with a thick layer of
twisted wire..maybe and chemical protected.. I also have rats, but they didn't dare to break their teeth here:))
  • Moderator
  • Moderator
19 Oct 2022 13:12 #254521 by tommylight
Just took a break from programing the tool changer. :)
  • Masiwood123
  • Platinum Member
  • Platinum Member
19 Oct 2022 13:20 #254523 by Masiwood123
that's how you should defragment your brain, then everything will be in one breath ;)..who knows how long I would stay without a break if I didn't have current jobs that I live off ..the weekend is kingdom
17 Dec 2024 14:08 #316862 by Lcvette
Replied by Lcvette on topic wiring MPGs to 7i96s
MPG1-A 7I96S IN0
MPG1-B 7I96S IN1
MPG2-A 7I96S IN2
MPG2-B 7I96S IN3
GND 7I96 IN COMMON
This does mean the other 7I96S inputs are sinking inputs
(pull high to activate)
quick sanity check, first time looking at the 7i96s, if an MPG is connected to IN1,2 and is a 5v mpg, do the remaining inputs need to be 5v also or can they be 24v? ie is mixing voltages ok here?
17 Dec 2024 15:43 #316871 by PCW
Replied by PCW on topic wiring MPGs to 7i96s
As long as input-common is GND you can mix input voltages.
The following user(s) said Thank You: Lcvette
17 Dec 2024 16:19 #316876 by Lcvette
Thanks Peter!
05 Jan 2025 21:22 #318172 by Lcvette
Yes, the only thing different is the source pin of the counts
having a heck of a time figuring this out, have the axis select working and the increments select working and showing in halshow but cannot get the counts to move.  wired as shown in the example what did i miss?  is there a setting for the 7i96s? jumpers? didn't see anything for mpg in the manual for it, only for the encoder input for spindle.  anyone have a suggestion?  mpg.hal pastebin below:
pastebin.com/6zAJv63y
Thanks in advance!
05 Jan 2025 21:25 - 05 Jan 2025 21:30 #318173 by Lcvette
I have TB3 input common as ground to the 24v power supply and inputs are 24v+ to the individual input temrinals, the mpg is pulling 5v+ power and ground from TB1-1 & 6.  so ground should be common for mpg and normal inputs.  still not working, must be something in my hal?
Last edit: 05 Jan 2025 21:30 by Lcvette.
Moderators: PCW, jmelson
Time to create page: 0.136 seconds
