wiring MPGs to 7i96s
- Lcvette
- Thank you received: 784
05 Jan 2025 22:07 #318175
by Lcvette
Replied by Lcvette on topic wiring MPGs to 7i96s
Ok moved mpg gnd to tb3-12, still nothing, im really stumped on this one.
- Thank you received: 5330
05 Jan 2025 22:27 #318176
Replied by PCW on topic wiring MPGs to 7i96s
do the inputs:
hm2_7i96s.0.inm.00.input-00
hm2_7i96s.0.inm.00.input-01
Change when you move the jog wheel?
If not, there may be a wiring error or the MPG A/B outputs don't have enough swing.
Check the high level at the 7I96S inputs. if lower than say 3.5V they may
need a pullup resistor to 5V to get enough swing for the isolated inputs
If the swing is too low, another option is to tie the 7I96S input common to +5V
(but this forces all inputs to be sourcing 5V type)
The following user(s) said Thank You: Lcvette
- Lcvette
06 Jan 2025 14:18 #318227
by Lcvette
yeah that would require a major bit of changes and components. is there a reason it couldn't use the 24v field supply for the mpg vcc/gnd instead of 5v? wold that resolve if it was a low voltage issue?
06 Jan 2025 14:29 #318228
Well using 24V power might resolve the MPG use permanently with fire and smoke if it's a 5V MPG (most are)
Did you check the input levels? If the A/B high levels are less than say 3.5V, a pullup resistor to 5V may be needed
- Lcvette
06 Jan 2025 17:45 #318244
by Lcvette
good call, it is a 5v..lol ok will check the voltage at the mesa inputs and report back! Thank Peter!
- COFHAL
- Thank you received: 62
05 Dec 2025 22:23 #339775
by COFHAL
Replied by COFHAL on topic wiring MPGs to 7i96s
I have a similar setup on my lathe; I'll send it to you later.
- COFHAL
06 Dec 2025 15:13 #339797
by COFHAL
Time to create page: 0.447 seconds
