trying to decide...wait for new 7i76E or get 7i96S
28 Oct 2022 17:44 #255318 by rubes
If I understand correctly the 7i76E is being redesigned and may be available in the near future? But I see  that the 7i96S is currently available @mesaus. Other than the additional I/O of the 7i76E am I giving up much else? I could always get an expansion option later if I need more I/O.
The 7i96S seems a bit more flexible anyway with ability to do sinking or sourcing I/O too.
Just wondering if the new 7i76E is worth waiting for because it may have better performance or new features?
Rubes
p.s. I currently have a 5i25 and 7i76 on a lathe that I am pretty happy with.
  • Moderator
  • Moderator
28 Oct 2022 22:14 - 28 Oct 2022 23:14 #255345 by tommylight
Mesa 7i96S does not have a spindle VFD output for 0-10V, 7i76 and 7i76E do have that.
I think that is the only difference, besides I/O.
And yes, having sinking and sourcing I/O is a very nice feature.
Edit:
Wrong info, Mesa 7i96S does have spindle VFD output, Mesa 7i96 had not. I have a 7i96.
Sorry for the mess.
Last edit: 28 Oct 2022 23:14 by tommylight. Reason: wrong info, sorry.
28 Oct 2022 22:46 #255347 by PCW
The 7I96S _does_ have an analog spindle output.
(The 7I96 does not)
The following user(s) said Thank You: rubes, snowgoer540
  • Moderator
  • Moderator
28 Oct 2022 23:10 #255352 by tommylight
(The 7I96 does not)
Oh cr@p !
Sorry PCW, i must have a 7i96, apparently.
Corrected above.
28 Oct 2022 23:12 #255353 by rubes
Thanx...7i96S it is then.
30 Oct 2022 18:56 #255476 by andypugh
We added 7i96S support to the 2.8.4 release specifically because it is actually available,
30 Oct 2022 20:28 #255485 by rubes
arg...now I need a new PC for this too :-(
I had an old Dell series 3000 box laying around I was planning on using since I always heard "Linuxcnc will run on any old $25 garage sale computer". Guess those days are gone now too. I can load 2.7 on it but not 2.8.x since its only a 32 bit machine apparently. I'm limited to installing from the live CD since I am nowhere near smart enough to do it any other way.
30 Oct 2022 21:36 #255492 by andypugh
Are you sure it is only 32 bit?
"The Pentium-4 2.8GHz released in November of 2002 was the last desktop 32-bit CPU."
It might be running a 32 bit OS at the moment, but unless it is very old it might well be a 64 bit CPU.
30 Oct 2022 22:23 #255500 by rubes
pretty sure.
when I try to load the 2.8.4 live CD it tells me;
"this kernel requires a x86-64 CPU, but it only detected a i686 CPU..."
I was able to load the 2.7.14 live CD though. But that won't support the 7i96S. right?
30 Oct 2022 22:42 #255505 by andypugh
LinuxCNC 2.8 is supported back to Ubuntu 12.04.
You should be able to update just LinuxCNC and not the OS / realtime.
Install the 2.7 live CD then update to 2.8: linuxcnc.org/docs/stable/html/getting-st...dating-linuxcnc.html
Moderators: PCW, jmelson
Time to create page: 0.121 seconds
