I didn't have a programmer at hand and found a very cheap option xilinx virtual cable.
It flashes perfectly. You just need to solder another contact to the ground on the board.
TDI = 4, TDO = 5, TCK = 6, TMS = 7, GND
Author's page where you can download
gitee.com/xiaowuzxc/ESP32-XVC
"Over-the-air" programming over ESP32-C3
For IMPACT ise configuration JTAG spartan 6 xc6slx16
Can also configure for programming in flash memory in impact
Your host can find out from any program for scanning the ip environment.On my phone WOM WIFI
For example IMPACT
xilinx_xvc host=host=192.168.0.103:2542 disableversioncheck=true
If there is no ISE Xilinx there is a standalone programmer openFPGALoader
For openFPGALoader configuration spartan 6 xc6slx16
Write-flash JTAG to SPI bridge -f
sudo openFPGALoader -c xvc-client --ip <your ip> --port 2542 --fpga-part xc6slx16 -f <your bit file>
Write-sram JTAG -m
sudo openFPGALoader -c xvc-client --ip <your ip> --port 2542 --fpga-part xc6slx16 -m <your bit file>
For example
sudo openFPGALoader -c xvc-client --ip 192.168.0.103 --port 2542 --fpga-part xc6slx16 -f rv901t_4out__3stepgen_2enc_1pwm.bit
sudo openFPGALoader -c xvc-client --ip 192.168.0.103 --port 2542 --fpga-part xc6slx16 -m rv901t_4out__3stepgen_2enc_1pwm.bit
sudo apt install git gzip libftdi1-2 libftdi1-dev libhidapi-dev libudev-dev zlib1g-dev cmake pkg-config make g++
git clone
github.com/trabucayre/openFPGALoader
cd openFPGALoader
mkdir build
cd build
cmake ..
cmake --build .
sudo make install
