New project, litehm2: a hostmot2 port to linsn rv901t
2 years 7 months ago #295930 by xu
Thank you, sir
2 years 7 months ago #296022 by xu
gentlemen . bit file still cannot be generated
2 years 7 months ago - 2 years 7 months ago #296802 by Spacehitchhiker42
Is there any massively insurmountable reason that this project wouldn't work with a Trion T20 FPGA? I did notice that SRAM was mentioned in a previous post, does this require an external SRAM chip or does it use internal FPGA resources?
Last edit: 2 years 7 months ago by Spacehitchhiker42.
2 years 7 months ago #296843 by PCW
It should be possible since the HM2 source that supports the T20
is available. I would expect that the on-chip RAM is sufficient
2 years 7 months ago #296873 by Spacehitchhiker42
I did notice that in litehm2.py there are imports for "M12L64322a" and "GENSDRPHY", though they do not appear to be used anywhere. I just wanted to confirm that they aren't required for functionality.
2 years 7 months ago #297061 by xu
How do I use two 901T boards connected to the switch at the same time?
In addition to setting the IP address of the card 10.10.10.10 and 10.10.10.11 , how does the HAL know that it is the only IO pin
Moderators: PCW, jmelson
Time to create page: 0.406 seconds
