New project, litehm2: a hostmot2 port to linsn rv901t
1 year 8 months ago - 1 year 7 months ago #321785 by M4MazakUser
Hoping for some advice, things to check.
I have In rv901t board running,  correct firmware,  i disabled most os the mdb2hal stuff in hal to get it to run. I have modded the board as posted on this post, the j601 port works for outputs and tests well. However the j600 port isn't working as input. If i mod my hal file so one of the inputs (on the j600 port) is an output it works as one. ( setp ***** is_output true.  - or something like that) shouldn't the firmware be setting it as input?
edit # found the problem,  page 8 note that the bit file on github is not suited to a modded board. So use your own created bitfile or the page 8 one.
Last edit: 1 year 7 months ago by M4MazakUser. Reason: Extra stuff
1 year 7 months ago #323746 by xu
SIR Could you advise how to implement the SSI encoder configuration in hostmot2.py for 901T module compatibility?
Moderators: PCW, jmelson
Time to create page: 0.185 seconds
