The config file may have the name whatever you want.Add PATH="/opt/oss-cad-suite/bin:/opt/riscv/bin:$PATH" still gives the same alarm. The xxx.conf file must be renamed "board.conf" before make can run.
It is already installed in /opt/riscv. The $PATH doesn't contain the path to it.Thank you. Because the virtual machine cannot access the Internet due to the network card, the Risc-v toolchain cannot be installed.
Please find attached .bit file based on this configOkay, sir, this is too difficult for me. I used the conf file you wrote and changed it to see if you can help me generate a .bin .bit file. Sorry, I am using a translation software and my expression may not be accurate. Thank you, sir
