New project, litehm2: a hostmot2 port to linsn rv901t
3 years 3 months ago #274655 by sensille
Please check if the config suits your needs. The pin assignment is different.
File Name: rv901t_ily....bit.txt
File Size:454.22 KB
File Name: rv901t_ily...conf.txt
File Size:2.41 KB
3 years 3 months ago #274656 by sensille
I pushed some commits to master that add the modules inm, inmux and sserial. The latter two are untested.
3 years 3 months ago #274777 by tuxcnc
New bitstream is attached
If you are so polite, I will also ask.
File Name: tuxcnc-mod.conf.txt
File Size:2.53 KB
3 years 3 months ago - 3 years 3 months ago #274782 by IlyaKw
To be able to "compile" gateware for this project I have made virtual machine based on Debian 9. The image contains everything you need to do this.
I would like to support this project so I want to share this with those who are interested. The image weighs ca. 13GB. Please find attached archive with .torrent file.
All you need are located in /opt directory.
1. su -
2. You should place your config to /opt/litehm2/configs
3. From /opt/litehm2/ enter make
If your config is correct then during compilation, a message will appear about the unavailability of the "xst" component.
Enter the command
. /opt/Xilinx/14.7/ISE_DS/settings64.sh
Again make
Successful compilations
File Name: litex_cnc.rar
File Size:126.56 KB
Last edit: 3 years 3 months ago by IlyaKw. Reason: Other
3 years 3 months ago #274804 by sensille
File Size:2.53 KB
Attached. Let me know if it works and when you need any modifications.
File Name: tuxcnc-mod.bit.txt
File Size:454.22 KB
3 years 3 months ago #274825 by xu
Hands are too stupid ,
Two RV901T boards have been broken
Moderators: PCW, jmelson
Time to create page: 0.196 seconds
