7i96S card setup issues -- board discovery & red LED
- Thank you received: 7491
31 Dec 2022 12:07 #260635
Replied by tommylight on topic 7i96S card setup issues -- board discovery & red LED
You are running Linux Mint 21, so builbot does not work with premade debs, compiling does work.
On the forum, section "installing LinuxCNC", there is a guide for Mint21 pinned somewhere at the top, use that, the links are for the latest Debian build that works on Mint.
- Doug @ Design8Studio.com
- Thank you received: 46
31 Dec 2022 13:27 #260639
by Doug @ Design8Studio.com
Replied by Doug @ Design8Studio.com on topic 7i96S card setup issues -- board discovery & red LED
I'm giving up on Mint (2.9) and attempting to go from scratch with Debian Buster (2.8.4) since it is said to be compatible with 7i96S and seems to be the more accepted path.
31 Dec 2022 13:30 #260640
Thanks, Tommylight, for the helpful info, however, my the time I saw it I had already scrapped Mint in process of switching to Buster. I got the sense that Mint is not the more accepted path.
- Thank you received: 5334
31 Dec 2022 16:21 #260655
Replied by PCW on topic 7i96S card setup issues -- board discovery & red LED
You might try side stepping the LinuxCNC install issues by using JTs mesact configuration tool instead of pncconf
(or installing the 2.8.4 ISO)
31 Dec 2022 17:53 #260667
I had already switched to starting from scratch with 2.8.4 ISO. However, even after having done so, there are still issues. Two things:
One, on the MESA Card 0 setup TB3, inputs, the menu for "Plasma" choices disappeared, so, for instance, I cannot choose "Float Z" for the needed input. None of the Plasma choices are showing. I tried both 7i96 and 7i96S choices in the drop down, and tried both firmware options, d, and dpl, and nothing seems to make the "Plasma" menu option show up.
Two, the board discovery still is not working. I am getting the following error when trying board discovery.
At this point, in desperation, I guess I am left to look into using JTs mesact configuration tool instead of pncconf.
31 Dec 2022 18:02 #260668
31 Dec 2022 18:29 #260670
Perhaps the Plasma options are not supposed to show yet. However, somehow on my initial install, which was based on Mint, the Plasma options were showing from the start.
31 Dec 2022 19:31 #260672
I didn't realize you were setting up a plasma machine. If you wish to use Plasmac I think you need to run master (was 2.9 and is 2.10 currently)
The following user(s) said Thank You: Doug @ Design8Studio.com
01 Jan 2023 03:17 - 01 Jan 2023 03:19 #260695
OK, but I'm a bit confused. The PlasmaC user guide says "The preferred method for installing LinuxCNC (which contains PlasmaC by default) is via an ISO image as described below."
Does your instruction here mean that 2.8.4 from the main branch (using Buster) does not contain PlasmaC?
Last edit: 01 Jan 2023 03:19 by Doug @ Design8Studio.com.
- phillc54
- Thank you received: 2100
01 Jan 2023 03:21 #260696
by phillc54
Replied by phillc54 on topic 7i96S card setup issues -- board discovery & red LED
After you have installed the ISO then upgrade to master (2.10). (2.9 is not yet available on the buildbot because of the recent changes)
linuxcnc.org/docs/devel/html/plasma/qtpl...x_with_linuxcnc_v2_8
Time to create page: 0.524 seconds
