LitexCNC: firmware and driver for 5A-75B and 5A-75E
05 May 2024 00:09 #299773 by Ehsan_R
Might be instructive to plot that commanded and feedback joint positions
when index enable goes false
According to what I observed in halshow, position-cmd becomes zero immediately, but position-feedback and position-prediction stop after some change.
05 May 2024 00:17 #299774 by PCW
Ahh, I missed something, you would need to use encoder feedback for homing to index
unless your firmware supports stepgen homing to index (because the stepgen position
feedback is not zeroed on index)
05 May 2024 01:42 #299776 by Ehsan_R
I did not understand exactly what to do
Can you explain more?
05 May 2024 01:53 #299777 by PCW
For this to work, you would have to have actual feedback from the encoder
(connected in hal) or firmware that supports a stepgen index input
It might be possible to do this in software (hal) but it would be fairly complex
05 May 2024 13:42 #299805 by Ehsan_R
The fact is that I do not have much expertise in using Linux CNC.
Is it possible for you to guide me in doing this?
05 May 2024 13:45 #299806 by Ehsan_R
I encountered a strange problem while using Litex for some time.
This problem is that when I close the linuxcnc software or disable the machine power key, the motors automatically start moving at a very low speed.
Does anyone know how to fix this?
Does anyone have a solution for this problem?
05 May 2024 14:05 #299808 by tommylight
I did, you ignored it.
Short cables, shielded preferably, properly grounded.
05 May 2024 14:33 #299811 by PCW
If the firmware does not support index homing on stepgen systems, it's a bit complex because
you now must setup a PID loop using encoder feedback and use the stepgen in velocity mode.
You could use a pncconf created configuration as a sample of this kind of hal setup.
You might ask if LitexCNC firmware can support index input on stepgen systems, because
this would be a much simpler path if that can be done.
05 May 2024 15:02 #299814 by Ehsan_R
Do you believe this is due to the effects of noise?
So how does the watchdog work?
Shouldn't all functions of the board stop quickly after disconnecting the board and the software?
05 May 2024 15:06 #299816 by Ehsan_R
Thank you for your reply
I will do this solution and tell you the result
Moderators: PCW, jmelson
Time to create page: 0.203 seconds
