7i77 encoder split to amp and servo
- blazini36
- Thank you received: 167
19 May 2024 00:43 #300950
by blazini36
Replied by blazini36 on topic 7i77 encoder split to amp and servo
Well you can do alot of things, doesn't mean it's always a good idea. Somebody just posted about those CUI encoders that according to the datasheet don't even drive enough current to operate the receivers on a Mesa card according it it's manual.....maybe it'll work, probably not a good idea. When you start having problems you have to ask "what are the things I did that were not good idea?" If it just works, why bother asking?
I have no idea what kinda drives or encoders we're even talking about here, just making suggestions specific to the questions that were asked.
- OT-CNC
- Thank you received: 75
19 May 2024 04:31 #300952
by OT-CNC
Replied by OT-CNC on topic 7i77 encoder split to amp and servo
PCW,
Nice board.
I lack some fundamental electrical knowledge. In general, on a line driver type differential encoder, if the receiver is only single ended (my drive), it was my understanding that one can still read in just the A and B channels. If so, do /A and /B need further termination or can they be left floating/unconnected?
Or is it better to just get a single ended encoder if the receiver is single ended?
Tommylight,
I have a split setup on a lathe spindle that works very well with rigid tapping / threading and css. I'm reading in differential on both ends one to encoder card on vfd and the other to 7i77 for velocity control, so not trying something odd like current setup.
Current problem is trying to get a 4th axis indexer working. The drive (AMC ab30a200) only reads in single ended encoder for velocity feedback. I'm not sure why a new analog drive would have limited encoder channels in addition there is no encoder out from the drive to linuxcnc.
I think most of the digital drives have the additional encoder output. Unless I'm missing something, I'm forced to split it if I want encoder feedback.
One option is I can use current mode in the drive and read in the encoder on 7i77 only. Unfortunately I can't get good shaft lock in current mode.
Best option so far is hall velocity feedback in the drive and encoder to 7i77. Shaft lock is good but runs somewhat rough. Suspecting noise and bad encoder signals. This drive is not isolated. That was an extra option.
Nice board.
Tommylight,
- Thank you received: 7490
19 May 2024 12:36 #300960
Replied by tommylight on topic 7i77 encoder split to amp and servo
3 very fast optocouplers would be needed to have full isolation, if you need ABZ signals.
If you already have drive and Mesa wired and working, use a DVM to measure the AC and DC voltage between drive encoder gnd and Mesa encoder input GND, any reading above 0.1V means using optos, but if they are under 0.1V it will probably be safe to wire just ABZ signal pins to Mesa.
You have to measure those with drives off and again with all drives on and working as drives cause a lot of EMI.
It would be even better if you have a scope to actually see how much interference is there as the DVM is not very good at that.
Again, do this at your own risk, there are to many variables there to be certain.
- OT-CNC
26 Jul 2024 02:11 #306052
by OT-CNC
I ended up using the encoder y board from mesa which seems to be working fine with the addition of having swapped the servo drive to an isolated version.
