Bricked Mesa 7i92T
11 months 3 weeks ago #337926 by PCW
Replied by PCW on topic Bricked Mesa 7i92T
It comes down to what pinout you need.
What is the 7I92T connected to?
That is, what breakout board are you using?
11 months 3 weeks ago #338022 by FPVUALAB
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Hello! Thank you for your support! I only use 7i91th.
11 months 3 weeks ago #338028 by PCW
You can look at the .pin files in the firmware directory
to choose a appropriate pinout
7i92t_5abob_encd.bin for example has 5 stepgens and 6 encoders
Note that if you connect directly to encoders and motor drives:
1. The 7I92T I/O pins are like a bare parallel port pins and will be instantly damaged if connected to a voltage outside the -0.5 to +7V range. This is easy to do if system grounding is not 100% correct.
2. If you use bare 7I92T outputs to connect to step motor drives, they should be used in a a sinking configuration, as that is the only way to get full 5V drive:
DRIVE 7I92T
PUL+ +5V
PUL- 7I92 STEP PIN
DIR+ +5V
DIR- 7I92 DIR PIN
11 months 3 weeks ago #338039 by FPVUALAB
Does this firmware version also contain pins for ‘End Stop’ for 4 axes?
Does this mean that I have to use optocouplers?
What does ‘a sinking configuration’ mean?
Please tell me, can I use encoders from the Mitutoyo AT111-100F або AT111-200S series?
11 months 3 weeks ago #338041 by FPVUALAB
I have:
Stepper motor drivers DQ542MA
Mesa 7i92TH board (26 pins)
Nema 23 motors
Inductive limit switch NC NPN. BN 10-30V BU0V
C38S6G5-1024Z-G24N DC5-24V encoder
4-channel PC817 optocoupler isolation module
SINO 0.001 mm linear encoder optical scale
24V 10A power supply
Spindel Servo Motor 1000W
Purpose:
4 axes with optical rulers
One rotary axis with rotary encoder
LinuxCNC control
11 months 3 weeks ago #338042 by PCW
You can use any unassigned GPIO pin  as an input so limit/home switches are supported
Optocoupled step drive wiring:
Sinking:
DRIVE DIR+ --> +5V
CONTROLLER DIR- --> DRIVE DIR-
Sourcing:
Drive DIR- --> GND
CONTROLLER DIR+ DRIVE DIR +
Most step drives have optocouplers built in
BUT the 7I92T is really not intended for direct connection to field wiring.
It will work but a single mistake with grounding can easily damage the 7I92T.
The 7I92T was really designed as a parallel port equivalent device with added features
and is intended to work with parallel port (or Mesa) breakout boards.
Moderators: PCW, jmelson
Time to create page: 0.082 seconds
