error finishing read!
2 years 4 months ago #302180 by Anton
Replied by Anton on topic error finishing read!
yes of course
2 years 4 months ago #302189 by chris@cnc
Replied by chris@cnc on topic error finishing read!
the screenshot you sent, it shows "no_isolcpus". I would try „isolcpus=5.7“ in grub command line.
2 years 4 months ago #302194 by Anton
Hi unfortunately grub command line doesn't tell me anything. how do i get there and what command do i have to enter there?
2 years 4 months ago #302222 by chris@cnc
edit the grub command boot file
sudo nano /etc/default/grub
Find the line: GRUB_CMDLINE_LINUX_DEFAULT=""
edit to : GRUB_CMDLINE_LINUX_DEFAULT="isolcpus=5,7"
Then save and exit: ctrl+x then press "y" to confirm
sudo update-grub
sudo reboot
2 years 4 months ago #302223 by Anton
Thank you for the information.
I thought it would be more complicated.
If I have understood correctly, then cores 5 to 7 are isolated. But what are these cores used for?
Don't you still have to assign the IRQ from the network card to a core?
I'll try later to see if Chris's instructions lead to an improvement.
2 years 4 months ago #302235 by Anton
Unfortunately, the behaviour has deteriorated again. After starting LinuxCNC, the finishing read error now appears immediately. The motors can no longer be moved at all. Perhaps this laptop is simply not suitable.
Attached is the histogram and the ping with isolcpus=5.7.
Moderators: PCW, jmelson
Time to create page: 0.160 seconds
