error finishing read!
2 years 4 months ago - 2 years 4 months ago #302149 by Anton
Replied by Anton on topic error finishing read!
No, I am already pinging from 192.168.1.120 to 192.168.1.121. In the text, I accidentally copied the IP from the PCW instructions. The ping works, it is probably a latency problem.
Last edit: 2 years 4 months ago by Anton.
2 years 4 months ago #302151 by tommylight
Replied by tommylight on topic error finishing read!
Sorry, missed that, no idea how but probably lack of sleep.
The 9.4nS time is way to much, there is another topic with similar results, so can you try this:
-click on "routen"
-check the "use this connection only for resources on this network"
-click OK
-click "save"
-close
-click on the network manager icon and click on "wired connection 1"
-pins as advised by PCW
2 years 4 months ago #302153 by Anton
Thank you very much, I will give it a try later.
Unfortunately, I can't evaluate the result of the ping and the histogram.
Which value is too large and how large should it be? best regards
2 years 4 months ago #302155 by tommylight
Your fist screenshot above (with the correct address :) ) shows on the last line the min/avg/max/mdev values, the max value is above 9.4.
Please do this ping test again after all the above clicks and report back, it would be helpful if we can pinpoint what causes such high network latency.
Thank you.
2 years 4 months ago #302170 by Anton
I have run the long ping test 3 times. Here are the 3 results for max:
First ping test: 4.2msĀ
Second ping test : 3.4ms
Third ping test: 15.9ms
So it didn't get any better.
Above in the attachment I had shown file /etc/network/interfaces.
There I had inserted lines for eth0 as described in man hm2_eth. Do I have to replace eth0 with enp5s0?
Greetings Anton
2 years 4 months ago #302172 by tommylight
Moderators: PCW, jmelson
