Hello,
I am now trying to get LinuxCNC to run stably on my fourth computer. It didn't work at all with the first two. The third and weakest one ran reasonably well but that was only a loaner.
The new one is now a Dell OptiPlex 3050 SFF with an i7. The histogram looks quite good +-30. Unfortunately, I'm having problems with the max ping times again (see attachment).
I have filmed the BIOS and network settings and you can see them here:
Are they OK or do I need to change something there?
PCW had written the following on page 1:
"If your PC has an Intel Ethernet chip make sure you disable IRQ coalescing
(man hm2_eth)"
However, my network card (enp1s0) is not listed in the networks file (see attachment). Where should I insert the entry described in man hm2_eth?
How can I determine whether the computer uses an Intel Ethernet chi at all?
Are there any other possibilities for the origin of the high ping times?
Could it also be due to the MESA card?
Best regards
