New update on STMBL
2 years 1 month ago #309766 by RDA
Replied by RDA on topic New update on STMBL
Who knows if is possible to use these boards in a industry plant? Is possible to certify a machine using these boards? (CE for example here in Europe)
Most likely no, usually components that can also be used individually, need to be certified, especially electrical ones. So to certify a machine with drives an motors, they should also bear their own CE.
To certify the drives, you have pretty much 2 options.
1. You do it on your own.
This is quite a big task, the only "difficult" one will be the EMC stuff, you need a radio room, you can find example in some universities etc. and then you need to fix your mistakes. Don't worry there will be mistakes and shit to take care of.
The other stuff is more documentation stuff like, manuals (EU is a bitch as technically the CE requires manuals to be in the target country's language, so in most cases english is not enough), risk assessments etc. This takes a lot of time and a lot of effort.
2. You give the task to a company like Intertek, TUV...
I have always gone this route, expensive but then you get all CE, UL, CSA done at the same time and you are somewhat covered as someone else signs your work. Even in this case the EMC is always done before in another place. Some schools example rent those radio rooms out 10x cheaper what the time at intertek costs. So you try to do everything that you pass all the radiated and conducted emissions at the final test site. This will save you thousands.
3. Mix of the 2, you do it on your own and get someone to consult and help.
Probably cheaper than example the intertek route but a lot of work.
Some of the directives related to servos would be:
Machinery Directive
2006/42/EC
EMC Directive
2014/30/EU
Low Voltage Directive
2014/35/EU
Then most likely ROHS and REACH (but I think its hard to buy components now days that dont comply to both).
Then to find the subsections from those, I would ask someone that actually knows about this. Or see from any "major" brand like yaskawa, panasonic, mitsubishi, siemens... and just go with what they certify with (they will all have them on the manuals).
The following user(s) said Thank You: Freak
2 years 1 month ago #309804 by tivoi
Replied by tivoi on topic New update on STMBL
high voltage + high power , use discerct igbt or IGBT moudle
2 years 1 month ago - 2 years 1 month ago #309842 by Freak
Replied by Freak on topic New update on STMBL
Thank you for sharing your insights, RDA. I've read about the certification process but have never actually gone through it myself. It doesn't make sense to certify a driver for just one machine, but in the future, if a design proves successful and gains popularity, certification could potentially be beneficial.
Regarding the candidate power modules, designing a driver for a discrete IGBT can be a challenging task. In the past, I've encountered issues with parasitic capacitance from a similar module attached above, which led to the destruction of a Siemens servo driver that I was working on. The integrated solution provided by these power modules really simplifies the design process in my opinion. However, it's worth noting that including rectification diodes in an integrated solution may be redundant for a modular array used in robot control, as the drivers in such an arrangement typically only contain the inverter stage and not the rectification stage.
The Onsemi NFVA25012NP2T is a good option to consider for designing a prototype.
Last edit: 2 years 1 month ago by Freak.
2 years 1 month ago #311045 by vre
Replied by vre on topic New update on STMBL
this drive supports fanuc pulsecoders
siemens resolvers and biss-ssi encoders?
2 years 3 weeks ago - 2 years 3 weeks ago #311574 by Freak
Yess, only the fanuc is a bit tricky to connect because the pinout on the drive, but should work. All the others will work without issues. You can find more info here: freakontrol.github.io/stmbl/docs/pinouts .
Keep in mind the documentation there is still temporary and I planned to reorganize and enrich it.
Last edit: 2 years 3 weeks ago by Freak.
The following user(s) said Thank You: vre, Aciera
2 years 3 weeks ago #311621 by vre
Do you sell pcbs with components(at least smd) mounted ?
Are you in Europe ?
Moderators: PCW, jmelson
Time to create page: 0.160 seconds
