New update on STMBL
7 months 2 weeks ago #344207 by arsenix
Replied by arsenix on topic New update on STMBL
I wanted to bump this thread and inquire if anyone was using the STMBL v5 on their LinuxCNC projects? With native SS support, small size and support for straight rectified 220v I have always felt it was an amazing solution. It is pretty well documented but I'm wondering how challenging it is to tune the drive for the motors once all setup? The instructions seem fairly straightforward but it is hard to know until you try!
Also big thanks to Freak for reviving this project!
The following user(s) said Thank You: tommylight, NWE
6 months 4 weeks ago #345175 by andypugh
Replied by andypugh on topic New update on STMBL
I suspect that the problem is getting hold of the actual hardware?
6 months 5 days ago - 6 months 5 days ago #345974 by vibram
Replied by vibram on topic New update on STMBL
Hello
So bad I missed this topic, I was looking for this board for years !!
One question regarding the doc
Feedback 0 will typically be the encoder or resolver mounted on the motor, and feedback 1 can be used to connect either Hall sensors for initial commutation or (potentially) scales mounted directly to the axes. See the  Pinouts section of this document for pin assignments and typical wiring color codes.
  So we can connect linear scale ? but does it include a PID closed feedback?
I sent you a message on matrix to get the price of a board please.
Thank you for your awesome work
Last edit: 6 months 5 days ago by vibram.
Moderators: PCW, jmelson
Time to create page: 0.056 seconds
