W5100S-EVB-PICO stepgenerator and encoder driver
- tuxcnc
- Thank you received: 55
02 Aug 2025 01:40 #332655
by tuxcnc
Tool moves while spindle stops, even if position is reached.
Replied by tuxcnc on topic W5100S-EVB-PICO stepgenerator and encoder driver
It is not true.Velocity estimation is unrelated to G33.1 as G33.1 only looks at position.
- Thank you received: 5334
02 Aug 2025 03:00 - 02 Aug 2025 05:13 #332656
Replied by PCW on topic W5100S-EVB-PICO stepgenerator and encoder driver
Sorry , I guess you are right, G33.1 also looks at the spindle speed
But this works better with good velocity estimation, Though as I mentioned
you cannot use position interpolation except for constant speed applications
like threading on a lathe.
This is wrong because the TP does use the velocity value:
It is precisely true, LinuxCNCs TP only looks at the encoders position
in G33.1 moves. There is no other information path.
Looking a bit more into this, It does not look like the encoder velocity
( spindle.spindle_num].spindleSpeedIn ) is used for position mode synchronized
moves (G33 G76 etc) but only velocity mode synchronized moves (G95).
At least with a quick look at tp.c
Last edit: 02 Aug 2025 05:13 by PCW.
- atrex77
- Thank you received: 24
02 Aug 2025 18:23 - 02 Aug 2025 18:25 #332686
by atrex77
Replied by atrex77 on topic W5100S-EVB-PICO stepgenerator and encoder driver
i think i found the correct solution for this problem in the pico examples
Last edit: 02 Aug 2025 18:25 by atrex77.
Time to create page: 0.153 seconds
