Chinese Mesa 7I92 from aliexpress NEW
25 Nov 2025 16:14 #339213 by PCW
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
It may be that the Fujitsu Mini PC (like many laptops) has some
built-in power management that cannot be disabled.
27 Nov 2025 19:23 #339339 by Ul
Replied by Ul on topic Chinese Mesa 7I92 from aliexpress NEW
If they did supply firmware, I would try re-writing it with:
mesaflash --device 7i92 --addr 10.10.10.10 --write  vendor_supplied_firmware_file_name.bit --reload
My Chinese 7i98 doesn't seem to have a fallback area, so I bricked one of mine by flashing a corrupted Chinese firmware. I wouldn't try again to flash it this way.
Since then I am doing it the Chinese way:
sudo mesaflash --device 7i92 --addr 192.168.1.121 --write 7i92.bit --fix --fallback
sudo mesaflash --device 7i92 --addr 192.168.1.121 --write 7i92.bit --fallback
sudo mesaflash --device 7i92 --addr 192.168.1.121 --reload --fallback
If the firmware doesn't work, it says: "No 7I98 board found" and only one LED is on.  So I know if the firmware is bad and I don't go further. After power cycling it, the previous firmware is loaded and it works again.
If it works (and only if it works), i continue with:
Then I power cycle it and check the pins:
sudo mesaflash --device 7i92 --addr 192.168.1.121 --readhmid
I've tested some original 7i92 and 7i98 bitfiles and they all work perfectly, so there is no point in using Chinese bitfiles except if the "7i92" card doesn't even look like a Mesa card and really needs a Chinese custom file. I believe, even the files supplied by the Chinese are mostly original files.
I also could flash a Chinese 7i98 fallback firmware called "7i92_fallback.bit" on a Chinese 7i92, so the 7i92 had 50 pins.
But it didn't brick, so I could flash the right firmware afterwards.
27 Nov 2025 19:47 - 27 Nov 2025 19:49 #339342 by PCW
On Xilinx based cards you can use any working bitfile for fallback.
It wont have the blinking INIT LED indicator but otherwise the same.
This will protect against things like a power failure during flash update
It will not protect against writing firmware that does not work but has a
valid chip type and CRC (like firmware for a different card)
If you do have working fallback and a bad primary (Good CRC but does not work),
it is possible to recover without JTAG by intentionally causing an error in the primary
flash file load (say by shorting out the flash chip SDO pin briefly at power up)
Last edit: 27 Nov 2025 19:49 by PCW.
27 Nov 2025 20:05 - 27 Nov 2025 20:08 #339343 by Ul
Thank you for the reply, but I just flashed at least the 3.3V power regulator with 24V on the still working 7i98 instead, so it will take some time for me to do the repair. Maybe I can even program it using raspberry GPIOs then.
By that coincidence I had an EEPROM with a working firmware, which I just soldered it on the bricked card. Now it works again, but the other one doesn't.
Last edit: 27 Nov 2025 20:08 by Ul.
29 Nov 2025 16:01 - 29 Nov 2025 16:04 #339432 by Sekai
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
Ok. got it to work with the intel itx board. the fujistu minipc is hopeless.
I got it with 7i92_G540x2D firmware, kind of weird to setup the pins. Is there a simple firmware?
For reference i'm planning to use an lathe like 400x1000 3 tons with live tooling so no Y axis (X axis, Z axis and C-axis)
Edit: BTW i used a chinese usb stick (USB 3.0) and when i install the linuxcnc it gave errors (like the password for the wifi did not work or it refuse to install grub loader, so i use another usb and it works like charm).
Last edit: 29 Nov 2025 16:04 by Sekai.
29 Nov 2025 16:21 #339436 by PCW
With a 7I92, you would normally chose firmware that matches the
pinout of the breakout board you use. The G540x2 firmware is made
to match the pinout of the Gecko G540 4 Axis step/dir drive.
A commonly use breakout board (BOB)  is the Sainsmart "Mach 5 Axis CNC" breakout
For the, you would use  "5ABOB" firmware
29 Nov 2025 19:29 #339445 by Sekai
youre right about the bob, but for now i dont have a bob.
For now i'm new to mesa card in general.
01 Dec 2025 08:08 #339560 by unknown
Replied by unknown on topic Chinese Mesa 7I92 from aliexpress NEW
I would like to apologise to the OP for my remarks to his original post.
I have been shown to be unkind and unhelpful. My fellow forum members have been very gracious.
The following user(s) said Thank You: tommylight, Clive S, coolfox
07 Jan 2026 02:43 - 07 Jan 2026 02:44 #341102 by leandrocontarini
Replied by leandrocontarini on topic Chinese Mesa 7I92 from aliexpress NEW
Aqui os 3 modelos que testei funcionaram bem.
Mas com .bit chinês
Last edit: 07 Jan 2026 02:44 by leandrocontarini.
19 Feb 2026 10:38 #343192 by jarcysgru
Replied by jarcysgru on topic Chinese Mesa 7I92 from aliexpress NEW
Witam kupiłem taką samą kartę i czekam na przesyłkę.
Moje pytanie to jakim napięciem zasilasz tą kartę , w opisie podają 24V max i czy tylko to wystarczy ?
Moderators: PCW, jmelson
Time to create page: 0.108 seconds
