Chinese Mesa 7I92 from aliexpress NEW
2 months 4 weeks ago #348367 by jarcysgru
Hello, I've run my second Chinese 7i92 board on the lathe. File 7i92_G540x2D. The SSK-MB2 board from BOB works fine.
2 months 4 weeks ago #348376 by tuxcnc
Hi.
I have got this Lenovo cable:
It is important this has 26 pin plug which can move or remove pins. (There are flat cable with fixed plug too.)
You have to make one 1mm hole because Mesa has all pins, but Lenovo motherboard's socket only 25.
When you remove bracket, the second plug fit BOB without problems.
Why removable pins are important?
1. You must move GND pins if you need 5V power from mesa socket.
2. The PC817 optocouplers on BOB have very low bandwith.
If you will to use 7i92_5ABOB_Enc.bit and configure encoders=1 in hal file, this fits PC817 optocouplers on BOB.
I removed three pins from cable plug and move them to second mesa socket and use them as limits connected to BOB.
I have E6B2CWZ6C 2500 p/r encoder working well with 5V power.
If you make encoder's cable ends with goldpin plugs (no matter how) you can fit them to Lenovo cable 26 pin plug.
Unfortunatelly I can't make photo, because I'm now in other place than my lathe.
The encoder works well with 2000 RPM. With PC817 optocouplers it will be only 200 rpm or less, I suppose.
Note, that E6B2CWZ6C manufacturer promised 100 kHz bandwith.
If your spindle can spin more, you may have to use less resolution encoder.
Moderators: PCW, jmelson
Time to create page: 0.405 seconds
