Chinese Mesa 7I92 from aliexpress NEW
11 months 1 week ago #339056 by PCW
Changing the IRQ coalesce settings does improve the ping times noticeably on Intel hardware,
but your 4-5 ms  peak ping time indicates other issues, likely related to power management.
My system with Intel MAC and default IRQ coalesce settings:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.316 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.250 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.251 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.250 ms
Same system with IRQ coalecing off:
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.116 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.106 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.107 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.106 ms
Have you disabled all power management in the system BIOS and grub?
Have you set isolcpus to the last CPU in the grub file?
Do you have idle=poll in the grub file as well?
(These are basic latency reducing steps for any LinuxCNC host)
linuxcnc.org/docs/html/install/latency-test.html
11 months 1 week ago #339077 by Sekai
I ran the rt_setup.sh from this post and it gets worst now i have 6 ms
forum.linuxcnc.org/38-general-linuxcnc-q...irq-affinity?start=0
I disable evething i could in the bios but i dont have irq settings in the bios.
11 months 1 week ago #339080 by imitheo
Hello can you share your e-mail, interested in knowing more about your adventure with this board.
11 months 1 week ago #339081 by rodw
Are you sure its an intel NIC? Its unusual to see an INTEL NIC with a enpxxx name.
If you have 2 NICs are you configuring the right one?
11 months 1 week ago #339090 by PCW
Yes, the lspci  list shows the only Ethernet is a Intel LM217
5 ms on Intel most likely means some power management is still enabled
maybe EEE or PCIE
Is this running on a laptop?
11 months 1 week ago - 11 months 1 week ago #339117 by Sekai
This is mini pc fujistu Q920
i disable about everything in the bios.
Still nothing
This is my current boot parameters with grub.
sudo chrt 99 ping -i .001 -q 10.10.10.10 -c 60000 PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data. --- 10.10.10.10 ping statistics --- 60000 packets transmitted, 60000 received, 0% packet loss, time 60239ms rtt min/avg/max/mdev = 0.101/0.251/5.325/0.141 ms
Edit: I put linuxcnc on miniatx motherboard with intel i5 4460 and realtek RTL8168 ethernet.
Last edit: 11 months 1 week ago by Sekai.
Moderators: PCW, jmelson
Time to create page: 0.337 seconds
