I've tried to update the system, but I get this:
joccnc@JocCnc:~$ sudo apt update
[sudo] password for joccnc:
Sorry, try again.
Ign:1 http://linuxcnc.org stretch InRelease
Err:2 http://linuxcnc.org stretch Release
Cannot initiate the connection to linuxcnc.org:80 (69.163.143.134). - connect (101: Network is unreachable)
Ign:3 http://security.debian.org/debian-security stretch/updates InRelease
Err:4 http://security.debian.org/debian-security stretch/updates Release
404 Not Found [IP: 151.101.2.132 80]
Ign:5 http://ftp.debian.org/debian stretch InRelease
Err:6 http://ftp.debian.org/debian stretch Release
404 Not Found [IP: 146.75.62.132 80]
Reading package lists... Done
E: The repository 'http://linuxcnc.org stretch Release' does no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://security.debian.org/debian-security stretch/updates Release' does no longer have a Release file.
E: The repository 'http://ftp.debian.org/debian stretch Release' does no longer have a Release file.
As I can understand, there's something wrong (it seems almost...impossible to not find anything. Windows maybe, but Linux.....): too old version (2.7.14)???.
Anyway, I'm a little bit demoralized...
2 years ago I made the last job (a double sided PCB) and everything was perfect, then shutdown the system.
I can't understand what happened.
Before keeping going on with making you waste your time (I don't want it), as per your experience my problems can be related to:
1) software (linuxcnc) failure?
2) Mesa board failure?
3) MB failure?
In case 1), if I install the last linuxcnc release, will it be any chance to retrieve my current setup and customization (hoping it can fix the current problem)? 4 years ago I've spent almost 4-5 months to set linuxcnc (and with your needfull support, by myself I can't do anything....) and customize my axis with the function I normally use, so lose everything is something I don't want to....
Anyway, please tell me your opinion, I'll follow your suggestions.
