hm2_modbus pktuart, probably a firmware request?
25 Feb 2026 20:54 #343499 by PCW
The physical PKTUART pins are assigned in the firmware source (the PIN_XXXXX.vhd file that was included in the zip file)
 (If that's what you meant)
25 Feb 2026 22:50 #343502 by tommylight
Replied by tommylight on topic hm2_modbus pktuart, probably a firmware request?
Moved to "driver boards"
05 Mar 2026 21:30 #343925 by jtrantow
Complete success with the lathe modbus communications. Much faster and works fantastic with the automatic gear detection.
forum.linuxcnc.org/10-advanced-configura...tion-updated-for-vfd
The following user(s) said Thank You: COFHAL
06 Mar 2026 17:57 #343948 by jtrantow
FYI, when I ran my full configuration the vfd would work correctly at startup but would fail after several commands. Sometimes after homing, sometimes after MDI commands, but seemed to lock up and stop sending commands to the VFD. No errors reported in hm2_modbus and did not recover after set/clr the modbus reset.
I looked at git repo and saw several updates after the 2.9.8 tag. I have not noticed any lockups since installing and running the RIP master. I do get a few dialog errors about PDU too small while running but I don't lose control of VFD.
Moderators: PCW, jmelson
