Pcmcia parallel card
- billykid
- Thank you received: 80
26 Dec 2010 11:17 #6251
by billykid
Pcmcia parallel card was created by billykid
hi, I wanted to try one card 7I43 - 400. pcmcia to parallel port.
these are the data ...
10:00.0 Parallel controller: Oxford Semiconductor Ltd OX9162 Mode 0 (parallel port) (prog-if 03)
Subsystem: Oxford Semiconductor Ltd Device 0000
Flags: medium devsel, IRQ 22
I/O ports at 5020
I/O ports at 5028
I/O ports at 5000
Memory at a8000000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Kernel driver in use: parport_pc
Kernel modules: parport_pc
At first look it looks like a standard parallel port ..
but it can also make sure epp.
does anyone know if you can configure it?
7i43 course with onboard epp in another pc works perfectly
Mauro
I/O ports at 5020
I/O ports at 5028
I/O ports at 5000
Mauro
- Thank you received: 5278
26 Dec 2010 18:39 - 26 Dec 2010 18:40 #6254
Replied by PCW on topic Re:Pcmcia parallel card
No guarantees but I think it will "just work".
The earlier OX12PCI840 PCI parallel port chip from Oxford (now PLX Tech)
works, so its likely the OX9162 will.
(its a PCI chip also, you have a Cardbus=PCI adapter)
Last edit: 26 Dec 2010 18:40 by PCW. Reason: spelling
- billykid
26 Dec 2010 18:54 #6255
by billykid
Replied by billykid on topic Re:Pcmcia parallel card
I read the top post mode0 parallel port.
I think it should be set to epp in another way.
but the address must be entered or automatically recognizes the 7i43?
thanks
Mauro
thanks
Mauro
27 Dec 2010 01:23 #6256
I think the latest versions of EMC allow you to specify LPT ports by logical # (0,1, 2 etc) )rather than address.
- billykid
27 Dec 2010 20:46 #6273
by billykid
adding the line ioaddr = 0x5020. hostmot2 driver led "init"and"done" go out but emc2 not start ...
[ 8431.290870] hm2: loading Mesa HostMot2 driver version 0.15
[ 8431.296628] hm2_7i43: loading HostMot2 Mesa 7i43 driver version 0.3
[ 8431.298679] hm2_7i43.0: firmware: requesting hm2/7i43/SVST4_4B.BIT
[ 8431.866316] hm2/hm2_7i43.0: invalid cookie, got 0xFEFEFEFE, expected 0x55AACAFE
[ 8431.866321] hm2/hm2_7i43.0: FPGA failed to initialize, or unexpected firmware?
[ 8431.866326] hm2_7i43.0: board at (ioaddr=0x5020, ioaddr_hi=0x5028, epp_wide ON) not found!
[ 8432.161420] hm2: unloading
[ 8432.216115] RTAI[math]: unloaded.
[ 8432.269868] SCHED releases registered named ALIEN RTGLBH
[ 8432.284699] RTAI[malloc]: unloaded.
[ 8432.384016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 8432.388235] I-pipe: Domain RTAI unregistered.
[ 8432.388245] RTAI[hal]: unmounted.
Mauro
Mauro
28 Dec 2010 21:22 #6290
Ick, looks like the port was never set into EPP mode (the 0xFEFEFEFE is probably the parallel data lines indicating DONE is low read in normal. non EPP mode)
I wonder if any code that sets the port into EPP mode requires the standard 0x400 offset between the normal and extended LPT control registers (instead of the 0x08 offset here)
- Thank you received: 5002
29 Dec 2010 21:30 #6320
Replied by andypugh on topic Re:Pcmcia parallel card
billykid wrote:
The port spacing is not the normal 0x400, so you might need to explicitly state the addr_hi in the parport load line. (I have no idea which is which
I/O ports at 5020
I/O ports at 5028
I/O ports at 5000
- billykid
29 Dec 2010 21:57 #6322
by billykid
In fact I put this line to specify address. but it seems to work only in standard mode.
I do not think can use these address.
if someone who understands English better than I can learn
makes me a big favor.
Thanks for Everything
Mauro
Mauro
- unbekannt 0815
27 Jul 2013 19:35 #37091
by unbekannt 0815
Replied by unbekannt 0815 on topic Pcmcia parallel card
Anyone solved the Problem? I also have a Delock Paralell PCMCIA Card with the same IO Adress.
I am not able to configure it to EMC2. Anyone can help me?
27 Jul 2013 20:35 #37092
What part is not working? This thread was related to setting the card to EPP to use a 7i43 board.
If you are not using a 7i43 then you do not need EPP.
Replied by andypugh on topic Pcmcia parallel card
Time to create page: 0.189 seconds
