Pcmcia parallel card
- unbekannt 0815
27 Jul 2013 20:43 #37094
by unbekannt 0815
Replied by unbekannt 0815 on topic Pcmcia parallel card
Sorry, i was misreading the thread. Looks like i need a better english.
- Online
- Thank you received: 4982
27 Jul 2013 21:57 #37096
So, can you describe the problem you have? What error messages are produced?
Replied by andypugh on topic Pcmcia parallel card
- unbekannt 0815
27 Jul 2013 22:13 #37098
by unbekannt 0815
I am trying to configure emc2 to work with that PCMCIA Card mentioned from the thread starter. I read that its important to switch on EPP so that it will work with that.
I replaced the io port to d020 when configuring emc2 with sherline pinout. I didnt get any connection yet. I didnt figure out yet if i have to put hand on my linux or on emc2.
- Online
28 Jul 2013 09:24 #37126
You do not need EPP for your Sherline. Any mode ought to work.
You might want to consider checking the p-port manually.
This widget should show a change when you short an input pin to a GND pin if you have the correct port address.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Parallel_Port_Tester
- unbekannt 0815
28 Jul 2013 17:47 #37140
by unbekannt 0815
I tried this but i get no reaction on the widget. Only when i Push on the Buttons the Signal went green as long as i push it. The Input Signals are green except one.
lspci -v give me this information
10:00.0 Parallel controller: Oxford Semiconductor Ltd OX9162 Mode 0 (parallel port) (prog-if 03)
Subsystem: Oxford Semiconductor Ltd Device 0000
Flags: medium devsel, IRQ 22
I/O ports at 5020
I/O ports at 5028
I/O ports at 5000
Memory at a8000000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Kernel driver in use: parport_pc
Kernel modules: parport_pc
So i think the Paralell Port should be working. Did i miss something?
I/O ports at 5020
I/O ports at 5028
I/O ports at 5000
- Online
28 Jul 2013 18:02 #37142
What address are you using in the HAL "loadrt" command?
I/O ports at 5020
I/O ports at 5028
I/O ports at 5000
- unbekannt 0815
28 Jul 2013 18:22 #37145
by unbekannt 0815
I am using 5020 as port adress. i allready tried all three adresses given me from lspci. Using 5028 let emc2 crash when starting.
You mean the HAL commando in my Config i created?
- Online
28 Jul 2013 19:16 #37151
"5020" or "0x5020" ?
The port addresses are in Hexadecimal. (but you can't tell in that case)
- unbekannt 0815
28 Jul 2013 19:19 #37152
by unbekannt 0815
0x5020 i am using.
- Online
28 Jul 2013 19:23 #37153
An earlier message showed that parport_pc was using the card.
If you start LinuxCNC (or the parport tester) then what does lsmod show? It may be that parport_pc is grabbing the card and not giving it to LinuxCNC.
When you said "EMC2 crashed when starting" what was the error message?
(We need more clues than you are giving)
Time to create page: 0.176 seconds
