Pcmcia parallel card
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
30 Jul 2013 02:13 #37243 by andypugh
Replied by andypugh on topic Pcmcia parallel card
The also stutters shortly when booting up. I can use it under Windows with Winpc-nc so the mill is running.
Try inverting the step signals.
30 Jul 2013 19:18 #37259 by unbekannt 0815
Replied by unbekannt 0815 on topic Pcmcia parallel card
They are alive :cheer:. At last i get them to run under stepconf when testing an axis.
Problem now is that after stepconf running emc the motors wont work. Getting latency error Messages. I think this is smi related.
Why i can test the Axis in stepconf and under emc2 they wont work?
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
30 Jul 2013 19:21 #37260 by andypugh
This is typically because the stepconf test doesn't do anything with the amp-enable signals. If the finished configuration does, but the sense of the enable pin is wrong, then amp-enable might be amp-disable.
30 Jul 2013 20:09 #37263 by unbekannt 0815
Well......you did it. Its working now except the smi related issue.
I have to configure now the spindles..need to get rid of the latency issue.
Thanks alot...without your help i wouldnt have made it this far. :)
Moderators: PCWjmelson
Time to create page: 0.095 seconds
