Mori MVJR Build Log
- Thank you received: 5272
- schmidtmotorworks
- Thank you received: 6
MINFERROR = 0.005
FERROR = 0.02
So now I am trying to do some experiments with a program that feeds but it stops on the first G1 and just sits there.
I tried this:
G20 G40 G90 G17
S400 M3
M8
F3.0
G0 X8.0 Y-1.4
G0 Z-0.175
G1 Y-0.890
And this:
G20 G40 G90 G17
S400 M3
M8
G0 X8.0 Y-1.4
G0 Z-0.175
G1 Y-0.890 F3.0
Another strange thing, when I use the touch-off button set to 0.0 after pressing OK the DRO does not say 0.0, in the Z axis it goes to -0.0024
The X axis does the same but to smaller amount like 0.0004
Any ideas what I might be doing wrong?
- robh
- Thank you received: 24
M30
or
%s
to show end of program, if running from a file..
should show the error on screen if axis interface.
G20 G40 G90 G17
S400 M3
M8
F3.0
G0 X8.0 Y-1.4
G0 Z-0.175
G1 Y-0.890
M30
program loads and runs here with above
- BigJohnT
- Thank you received: 1176
- schmidtmotorworks
I'll keep searching for a reason for this.
- BigJohnT
Do you have Feed Hold off?
- robh
turn on the DTG (distance to go) on axis its in menus option, and check to see if on the G01 line it shows a distance to travel or not also does it sho a velocity value on g01 line?
one realy wird shot in dark, try a G94 in your program.. if its in G95 it ould be in feed per rev mode and waiting for spindle feedback.. but i cant see why it would be, u never know, odd for axis/emc to stop and not show why in some way or form.
rob
- robh
if so, in the hal, emc will wait for spindle to be at speed before a feed command
rob
- schmidtmotorworks
one other thing is, do u have spindle at speed linked?
rob
That was it!!!!!!!!!!!!!! Way to go, I was at my wits end.
I took the M3 command out and it moves fine.
No I just need to find out where this link is and disable it or connect speed agreement.
- clkeck1
If its a wiring issue let me know I have mine hooked up and working.
Cory
