Mori MVJR Build Log
- schmidtmotorworks
- Thank you received: 6
first, output type _must_ be 2 for 7I48
I tried setting the output type to 2 but with that setting the spindle just turns about 5 rpm and has a high pitched whine.
When the output type is set to 1 it turns about 100 rpm and sounds normal, I just don't have control of the rpm.
I tried setting the scale to -6000 and it does reverse direction.
Just to make sure i have the 7i48 connected properly:
I have 2 wires connected relating to the spindle:
pin 23 to COMS
and
pin 24 to SGS1
I'll try testing the voltage next.
- Thank you received: 5272
This is not an experiment. This is how the hardware works.
Then verify that the 0-10V works unconnected to the drive
If that works connect to drive and check again
- schmidtmotorworks
Please Please Please do not use any other mode than 2 for a 7I48
I disconnected the wires from 23 and 24 then set the spindle speed to 6000, the voltage was 9.99
Checked the wires in the diagram to make sure they were right again, it is as described above.
Reconnected, no change.
is the voltage still 9.99V when connected to the spindle drive?
- schmidtmotorworks
When it is connected to the drive
Using MDI:
When the S is 6000 using M3 voltage is 0.639
When the S is 500 using M3 voltage is 0.610
Using the manual page
Pressing the spindle rotate button gets voltage 0.02
I suggest you disconnect the 7I48 before something gets damaged
You need to fix this
Are you absolutely sure about the polarity?
the ~.6V sure sounds like a diode across the 7I48 outputs
by connecting a 9V battery with a 1K Ohm series resistor to the spindle drives
analog input (disconnected from the 7I48 of course)
- schmidtmotorworks
OK so it looks like you have a dead short (perhaps a diode) across the 7I48 outputs
I'm not understanding your question about the polarity but i think you might be on to something.
I just checked the wire that connects to pin 25 and it has -24volts.
I don't know what to do though.
like a 0-10V analog driven spindle. -24V should be kept a long long ways away from the 7I48
Polarity meaning the voltage relative to ground (common) the black meter lead should always be on ground so we are talking about the same things here
Try the battery thing, if that doesnt work you are not going to have any luck with the 7I48 and unlike the 7I48 you are lot likely to destroy anything with a mis-connect...
- schmidtmotorworks
There are two wires that I have been using that come form the spindle drive,
One is identified as COMS
One is identified as SGS1
I assumed that COMS was a ground but it is also -24V.
I have no clue what to do now. Any ideas.
Sorry I didn't understand what you meant by the "battery thing" are you suggesting connecting a 9V batter to the wires to see what happens?
