Bridgeport Series 1 Anilam GXM retrofit
- drembedded
03 Mar 2012 01:06 #18307
by drembedded
Replied by drembedded on topic Re:Bridgeport Series 1 Anilam GXM retrofit
OK, this is getting interesting...
Booted up with the old drive on the new machine and EMC starts with no complaints. Its possible that somehow my hal and ini files got corrupted.
I'll tar them up again and move them to the new drive and see if that fixes things.
Thanks for the help!
- RayJr
- Thank you received: 4
03 Mar 2012 01:07 #18308
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Replied by RayJr on topic Re:Bridgeport Series 1 Anilam GXM retrofit
FYI
After version 2.5 build 626, you may need to install LinuxCNC (the new name!). it will remove EMC2.
The current build, as of 9:00pst was 904
Hope this helps
Ray M.
Hope this helps
Ray M.
Albert Einstein
- Thank you received: 5193
03 Mar 2012 01:08 #18309
Replied by PCW on topic Re:Bridgeport Series 1 Anilam GXM retrofit
(PCW sighs a sigh of relief that its not a PCI core issue...)
- drembedded
03 Mar 2012 01:15 #18310
by drembedded
False alarm. This must have been a newie user issue. I used the ini and hal from my old drive and now emc is happy when it starts, yeah!
Ray, regarding the version after 2.5 release 626... I thought I was getting the latest from the buildbot, According to buildbot.linuxcnc.org/ I should be using the following source:
deb buildbot.linuxcnc.org/ lucid v2.5_branch-rt
Should I be getting the latet from the development branch, "deb buildbot.linuxcnc.org/ lucid master-rt"??
- BigJohnT
- Thank you received: 1175
03 Mar 2012 01:17 #18311
by BigJohnT
Replied by BigJohnT on topic Re:Bridgeport Series 1 Anilam GXM retrofit
2.5 should be fine...
- RayJr
03 Mar 2012 01:20 #18312
by RayJr
Albert Einstein
I discovered this by accident a few days ago when looking into something else. This is because of the name change from EMC2 to LinuxCNC, that updates for Emc2 have ended, and is is now known as LinuxCNC. (wordy).
I used Synaptic package manager, searched for LinuxCNC, and installed it.
Ray M.
Ray M.
Albert Einstein
- RayJr
03 Mar 2012 01:26 - 03 Mar 2012 01:33 #18313
by RayJr
Albert Einstein
It looks to me as Feb 29 was the end of new builds for EMC2.
Check out: buildbot.linuxcnc.org/dists/
Ray M.
Ray M.
Albert Einstein
Last edit: 03 Mar 2012 01:33 by RayJr.
- drembedded
03 Mar 2012 01:39 #18314
by drembedded
Ray,
Thanks for the tip. I did install linuxcnc and was pleased to find that the synaptic package manager realized that linuxcnc is an update to emc and deleted emc prior to installing linuxcnc.
Cheers,
Michael
Cheers,
Michael
- drembedded
03 Mar 2012 01:41 - 07 Mar 2012 19:15 #18315
by drembedded
John, I'm looking forward to you doing the 5i25/7i77 upgrade on your BP. Theres all kinds of stuff about linuxcnc that I don't understand and I'm hoping to leverage what you do.
Last edit: 07 Mar 2012 19:15 by drembedded.
- drembedded
17 Mar 2012 02:06 - 17 Mar 2012 02:17 #18619
by drembedded
Making slow progress. I've got my scales (x and y) and encoder (Z) wired up but need still need to configure their step vales and correct direction (the LinuxCNC's DRO screen shows all three axis going negative when I move them in the positive direction.
I've disconnected the old control completely from the electronics that will stay in the machine but I haven't yet removed the control from the system. One thing I've noticed is an odd ticking sound, almost like high power arcing to ground and it happens about once a second. I've never heard this sound before since my old control's cooling fans were so loud. The sound is coming from the automatic oiler.
I'm assuming this is normal. Is this normal or abe-normal?
Last edit: 17 Mar 2012 02:17 by drembedded.
Time to create page: 0.108 seconds
