- Thank you received: 4
PCW wrote: 1. Buffers the FPGA signals to full 5V 24ma levels (and also supports differential output for some Fanuc drives)
2. Has protected Schmitt trigger 5V inputs
3. Handles the bidirectional nature of the PWM lines (they return drive status bits when DRDY is not asserted)
4. Has a 2 channel per Axis simultaneous sampling A-D for reading IS and IR so FOC can be implemented
Either in the FPGA or LinuxCNC (IS and IR are analog +-4.4V FS phase currents)
This is sounding rather more involved than I had assumed. I had thought that these motors had the old 4-wire commutation output.
