Emco Compact 5 interface with linuxcnc (painless)
9 years 10 months ago #84750 by Mysli
Hi Skunkworks,
I'd like to ask 2 questions, in spite of this thread being old.
First, what Settings did you use on the DIP switch, cause im a little confused about that (even though i have the original manual for the machine)
And also, would it be possible to interface a X and a Z limit switch directly to the parallelboard or isnt there enough pins left and would i need a pullup resistor for it?
Best Regards
Kasper Tulstrup
9 years 10 months ago #84908 by skunkworks
Could have sworn I posted this yesterday..
I never changed the switches iirc - they are all down.
electronicsam.com/images/emco/interfaceanddrive.JPG
sam
9 years 3 months ago #96107 by Line680
Hi!
New to Linux CNC and to my Emco compact 5 pc! :)
Very happy to find these files, great work! :)
...but it doesn't work with the most recent LinuxCNC? what version are you running ? LinuxCNC just quits when i try to load your config files.
/Stefan
9 years 3 months ago #96109 by skunkworks
can you post the error?
9 years 3 months ago #96110 by Line680
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.0
Machine configuration directory is '/home/stefan/linuxcnc/configs/Half-fullstepMorph'
Machine configuration file is 'emco-lathe.ini'
INIFILE=/home/stefan/linuxcnc/configs/Half-fullstepMorph/emco-lathe.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
emc/iotask/ioControl.cc 768: can't load tool table.
Found file(REL): ./emco-lathe.hal
Killing task linuxcncsvr, PID=3714
Debug file information:
./emco-lathe.hal:6: Can't find module 'probe_parport' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
3714
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007fe8cc00 (usable)
[ 0.000000] BIOS-e820: 000000007fe8cc00 - 000000007fe8ec00 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fe8ec00 - 000000007fe90c00 (ACPI data)
[ 0.000000] BIOS-e820: 000000007fe90c00 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Inc. Dimension 8400 /0J3492, BIOS A09 07/07/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7fe8c max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07FF00000 mask FFFF00000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36412000 - 37201000
[ 0.000000] ACPI: RSDP 000febf0 00014 (v00 DELL )
[ 0.000000] ACPI: RSDT 000fcc96 0003C (v01 DELL 8400 00000007 ASL 00000061)
[ 0.000000] ACPI: FACP 000fccd2 00074 (v01 DELL 8400 00000007 ASL 00000061)
[ 0.000000] ACPI: DSDT fffc76a0 02B21 (v01 DELL dt_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 7fe8cc00 00040
[ 0.000000] ACPI: SSDT fffca1c1 000A7 (v01 DELL st_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: APIC 000fcd46 00092 (v01 DELL 8400 00000007 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fcdd8 00028 (v01 DELL 8400 00000007 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fce00 0003E (v01 DELL 8400 00000007 ASL 00000061)
[ 0.000000] ACPI: HPET 000fce3e 00038 (v01 DELL 8400 00000007 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1158MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007fe8c
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x000000a0
[ 0.000000] 0: 0x00000100 -> 0x0007fe8c
[ 0.000000] On node 0 totalpages: 523804
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5412200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3952 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2318 pages used for memmap
[ 0.000000] HighMem zone: 294272 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x06] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x04] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x07] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x05] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7769000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519710
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=e3d7db9a-3640-4dbf-8ed3-b426c927bf90 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4191200 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007fe8c)
[ 0.000000] Memory: 2053208k/2095664k available (3495k kernel code, 42008k reserved, 1237k data, 416k init, 1186360k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f5008000 soft=f500a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3591.037 MHz processor.
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 7182.07 BogoMIPS (lpj=14364148)
[ 0.004011] pid_max: default: 32768 minimum: 301
[ 0.004075] Security Framework initialized
[ 0.004081] AppArmor: AppArmor disabled by boot time parameter
[ 0.004108] Mount-cache hash table entries: 512
[ 0.004378] Initializing cgroup subsys cpuacct
[ 0.004382] Initializing cgroup subsys memory
[ 0.004395] Initializing cgroup subsys devices
[ 0.004398] Initializing cgroup subsys freezer
[ 0.004401] Initializing cgroup subsys net_cls
[ 0.004404] Initializing cgroup subsys blkio
[ 0.004416] Initializing cgroup subsys perf_event
[ 0.004461] CPU: Physical Processor ID: 0
[ 0.004464] CPU: Processor Core ID: 0
[ 0.004467] mce: CPU supports 4 MCE banks
[ 0.004478] CPU0: Thermal monitoring enabled (TM1)
[ 0.004550] ACPI: Core revision 20120320
[ 0.037509] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.037888] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.077584] CPU0: Intel(R) Pentium(R) 4 CPU 3.60GHz stepping 04
[ 0.080004] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.080004] ... version: 0
[ 0.080004] ... bit width: 40
[ 0.080004] ... generic registers: 18
[ 0.080004] ... value mask: 000000ffffffffff
[ 0.080004] ... max period: 0000007fffffffff
[ 0.080004] ... fixed-purpose events: 0
[ 0.080004] ... event mask: 000000000003ffff
[ 0.088031] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.100034] CPU 1 irqstacks, hard=f507c000 soft=f507e000
[ 0.100038] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.112048] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.112112] Brought up 2 CPUs
[ 0.112118] Total of 2 processors activated (14364.14 BogoMIPS).
[ 0.112929] devtmpfs: initialized
[ 0.112929] PM: Registering ACPI NVS region [mem 0x7fe8cc00-0x7fe8ebff] (8192 bytes)
[ 0.112929] dummy:
[ 0.112929] NET: Registered protocol family 16
[ 0.112929] ACPI: bus type pci registered
[ 0.112929] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.112929] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.112929] PCI: Using MMCONFIG for extended config space
[ 0.112929] PCI: Using configuration type 1 for base access
[ 0.116141] bio: create slab <bio-0> at 0
[ 0.116208] ACPI: Added _OSI(Module Device)
[ 0.116208] ACPI: Added _OSI(Processor Device)
[ 0.116208] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.116208] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.116692] ACPI: EC: Look up EC in DSDT
[ 0.129126] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.138216] ACPI: Interpreter enabled
[ 0.138235] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.138288] ACPI: Using IOAPIC for interrupt routing
[ 0.185469] ACPI: No dock devices found.
[ 0.185480] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.189286] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.196843] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.196849] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.196853] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.196857] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xdfffffff] (ignored)
[ 0.196861] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xfebfffff] (ignored)
[ 0.196865] PCI: root bus 00: using default resources
[ 0.196922] PCI host bridge to bus 0000:00
[ 0.196927] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.196931] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.196947] pci 0000:00:00.0: [8086:2584] type 00 class 0x060000
[ 0.197012] pci 0000:00:01.0: [8086:2585] type 01 class 0x060400
[ 0.197063] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.197122] pci 0000:00:1c.0: [8086:2660] type 01 class 0x060400
[ 0.197196] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.197230] pci 0000:00:1c.1: [8086:2662] type 01 class 0x060400
[ 0.197302] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.197336] pci 0000:00:1d.0: [8086:2658] type 00 class 0x0c0300
[ 0.197388] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.197428] pci 0000:00:1d.1: [8086:2659] type 00 class 0x0c0300
[ 0.197480] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.197518] pci 0000:00:1d.2: [8086:265a] type 00 class 0x0c0300
[ 0.197568] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.197608] pci 0000:00:1d.3: [8086:265b] type 00 class 0x0c0300
[ 0.197659] pci 0000:00:1d.3: reg 20: [io 0xff20-0xff3f]
[ 0.197707] pci 0000:00:1d.7: [8086:265c] type 00 class 0x0c0320
[ 0.197732] pci 0000:00:1d.7: reg 10: [mem 0xffa80800-0xffa80bff]
[ 0.197817] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.197845] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.197916] pci 0000:00:1e.2: [8086:266e] type 00 class 0x040100
[ 0.197935] pci 0000:00:1e.2: reg 10: [io 0xec00-0xecff]
[ 0.197947] pci 0000:00:1e.2: reg 14: [io 0xe8c0-0xe8ff]
[ 0.197958] pci 0000:00:1e.2: reg 18: [mem 0xdffffa00-0xdffffbff]
[ 0.197970] pci 0000:00:1e.2: reg 1c: [mem 0xdffff900-0xdffff9ff]
[ 0.198015] pci 0000:00:1e.2: PME# supported from D0 D3hot D3cold
[ 0.198043] pci 0000:00:1f.0: [8086:2640] type 00 class 0x060100
[ 0.198136] pci 0000:00:1f.0: LPC Generic IO decode 1 PIO at 0c00-0c7f
[ 0.198141] pci 0000:00:1f.0: LPC Generic IO decode 2 PIO at 00e0-00ef
[ 0.198160] pci 0000:00:1f.1: [8086:266f] type 00 class 0x01018a
[ 0.198177] pci 0000:00:1f.1: reg 10: [io 0x01f0-0x01f7]
[ 0.198190] pci 0000:00:1f.1: reg 14: [io 0x03f4-0x03f7]
[ 0.198202] pci 0000:00:1f.1: reg 18: [io 0x0170-0x0177]
[ 0.198214] pci 0000:00:1f.1: reg 1c: [io 0x0374-0x0377]
[ 0.198227] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.198272] pci 0000:00:1f.2: [8086:2652] type 00 class 0x010601
[ 0.198292] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.198304] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.198315] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.198326] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.198338] pci 0000:00:1f.2: reg 20: [io 0xfea0-0xfeaf]
[ 0.198349] pci 0000:00:1f.2: reg 24: [mem 0xdffffc00-0xdfffffff]
[ 0.198378] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.198398] pci 0000:00:1f.3: [8086:266a] type 00 class 0x0c0500
[ 0.198461] pci 0000:00:1f.3: reg 20: [io 0xe8a0-0xe8bf]
[ 0.198556] pci 0000:01:00.0: [1002:5d57] type 00 class 0x030000
[ 0.198572] pci 0000:01:00.0: reg 10: [mem 0xc0000000-0xcfffffff pref]
[ 0.198583] pci 0000:01:00.0: reg 14: [io 0xdc00-0xdcff]
[ 0.198595] pci 0000:01:00.0: reg 18: [mem 0xdfde0000-0xdfdeffff]
[ 0.198628] pci 0000:01:00.0: reg 30: [mem 0xdfe00000-0xdfe1ffff pref]
[ 0.198654] pci 0000:01:00.0: supports D1 D2
[ 0.198682] pci 0000:01:00.1: [1002:5d77] type 00 class 0x038000
[ 0.198697] pci 0000:01:00.1: reg 10: [mem 0xdfdf0000-0xdfdfffff]
[ 0.198765] pci 0000:01:00.1: supports D1 D2
[ 0.198785] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.198797] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.198803] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.198808] pci 0000:00:01.0: bridge window [mem 0xdfd00000-0xdfefffff]
[ 0.198813] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff pref]
[ 0.198894] pci 0000:02:00.0: [14e4:1677] type 00 class 0x020000
[ 0.198925] pci 0000:02:00.0: reg 10: [mem 0xdfcf0000-0xdfcfffff 64bit]
[ 0.199038] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.199064] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.199077] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.199085] pci 0000:00:1c.0: bridge window [mem 0xdfc00000-0xdfcfffff]
[ 0.199142] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.199150] pci 0000:00:1c.1: bridge window [mem 0xdfb00000-0xdfbfffff]
[ 0.199199] pci 0000:04:01.0: [1102:0004] type 00 class 0x040100
[ 0.199222] pci 0000:04:01.0: reg 10: [io 0xccc0-0xccff]
[ 0.199304] pci 0000:04:01.0: supports D1 D2
[ 0.199330] pci 0000:04:01.2: [1102:4001] type 00 class 0x0c0010
[ 0.199354] pci 0000:04:01.2: reg 10: [mem 0xdfafb800-0xdfafbfff]
[ 0.199367] pci 0000:04:01.2: reg 14: [mem 0xdfafc000-0xdfafffff]
[ 0.199443] pci 0000:04:01.2: supports D1 D2
[ 0.199446] pci 0000:04:01.2: PME# supported from D0 D1 D2 D3hot
[ 0.199511] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.199517] pci 0000:00:1e.0: bridge window [io 0xc000-0xcfff]
[ 0.199523] pci 0000:00:1e.0: bridge window [mem 0xdfa00000-0xdfafffff]
[ 0.199532] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.199536] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.199558] pci_bus 0000:00: on NUMA node 0
[ 0.199565] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.200105] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.200782] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.201056] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI3._PRT]
[ 0.201331] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.201605] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.589949] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.590327] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.590703] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.591073] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.591448] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.592104] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.592479] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.592852] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.593008] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.593008] vgaarb: loaded
[ 0.593008] vgaarb: bridge control possible 0000:01:00.0
[ 0.593008] PCI: Using ACPI for IRQ routing
[ 0.600491] PCI: pci_cache_line_size set to 64 bytes
[ 0.600603] reserve RAM buffer: 000000007fe8cc00 - 000000007fffffff
[ 0.600795] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.600806] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.602836] Switching to clocksource hpet
[ 0.602934] pnp: PnP ACPI init
[ 0.602957] ACPI: bus type pnp registered
[ 0.603977] pnp 00:00: [bus 00-ff]
[ 0.603982] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.603987] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.603990] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.603995] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.603999] pnp 00:00: [mem 0x00000000 window]
[ 0.604014] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 0.604018] pnp 00:00: [mem 0xf0000000-0xfebfffff window]
[ 0.604073] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.606147] pnp 00:01: [io 0x0062-0x0063]
[ 0.606151] pnp 00:01: [io 0x0065-0x006f]
[ 0.606155] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.606158] pnp 00:01: [io 0x0800-0x085f]
[ 0.606162] pnp 00:01: [io 0x0c00-0x0c7f]
[ 0.606165] pnp 00:01: [io 0x0860-0x08ff]
[ 0.606239] system 00:01: [io 0x0800-0x085f] has been reserved
[ 0.606244] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 0.606251] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 0.606257] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.606389] pnp 00:02: [io 0x0080-0x009f]
[ 0.606393] pnp 00:02: [io 0x0000-0x001f]
[ 0.606397] pnp 00:02: [io 0x00c0-0x00df]
[ 0.606401] pnp 00:02: [dma 4]
[ 0.606442] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.606551] pnp 00:03: [io 0x00f0-0x00ff]
[ 0.606567] pnp 00:03: [irq 13]
[ 0.606607] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.606716] pnp 00:04: [io 0x0061]
[ 0.606757] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.606868] pnp 00:05: [io 0x0070-0x007f]
[ 0.606877] pnp 00:05: [irq 8]
[ 0.606921] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.609392] pnp 00:06: [io 0x0060]
[ 0.609396] pnp 00:06: [io 0x0064]
[ 0.609405] pnp 00:06: [irq 1]
[ 0.609458] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.614970] pnp 00:07: [io 0x0378-0x037f]
[ 0.614974] pnp 00:07: [io 0x0778-0x077f]
[ 0.614983] pnp 00:07: [irq 7]
[ 0.614987] pnp 00:07: [dma 0 disabled]
[ 0.615512] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.618049] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.618058] pnp 00:08: [irq 4]
[ 0.618275] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.628961] pnp 00:09: [mem 0x00000000-0x0009ffff]
[ 0.628965] pnp 00:09: [mem 0x00100000-0x00ffffff]
[ 0.628969] pnp 00:09: [mem 0x01000000-0x7fe8cbff]
[ 0.628973] pnp 00:09: [mem 0x000c0000-0x000fffff]
[ 0.628976] pnp 00:09: [mem 0xfec00000-0xfecfffff]
[ 0.628980] pnp 00:09: [mem 0xfee00000-0xfeefffff]
[ 0.628983] pnp 00:09: [mem 0xfed20000-0xfed9ffff]
[ 0.628987] pnp 00:09: [mem 0xffb00000-0xffbfffff]
[ 0.628990] pnp 00:09: [mem 0xffc00000-0xffffffff]
[ 0.629076] system 00:09: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.629083] system 00:09: [mem 0x00100000-0x00ffffff] could not be reserved
[ 0.629087] system 00:09: [mem 0x01000000-0x7fe8cbff] could not be reserved
[ 0.629092] system 00:09: [mem 0x000c0000-0x000fffff] could not be reserved
[ 0.629097] system 00:09: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 0.629101] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.629105] system 00:09: [mem 0xfed20000-0xfed9ffff] has been reserved
[ 0.629110] system 00:09: [mem 0xffb00000-0xffbfffff] has been reserved
[ 0.629114] system 00:09: [mem 0xffc00000-0xffffffff] has been reserved
[ 0.629119] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.629246] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.629250] pnp 00:0a: [mem 0xfeda0000-0xfedacfff]
[ 0.629330] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.629336] system 00:0a: [mem 0xfeda0000-0xfedacfff] has been reserved
[ 0.629341] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.629451] pnp 00:0b: [mem 0xfed00000-0xfed003ff]
[ 0.629506] pnp 00:0b: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.629517] pnp: PnP ACPI: found 12 devices
[ 0.629521] ACPI: ACPI bus type pnp unregistered
[ 0.629526] PnPBIOS: Disabled by ACPI PNP
[ 0.668252] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 0.668259] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 0.668272] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 0.668277] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 0.668297] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.668301] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.668306] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.668310] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.668316] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref]
[ 0.668321] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 0.668326] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.668331] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.668338] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.668342] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.668349] pci 0000:00:01.0: bridge window [mem 0xdfd00000-0xdfefffff]
[ 0.668354] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff pref]
[ 0.668361] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.668366] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.668373] pci 0000:00:1c.0: bridge window [mem 0xdfc00000-0xdfcfffff]
[ 0.668379] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff 64bit pref]
[ 0.668387] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.668391] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.668398] pci 0000:00:1c.1: bridge window [mem 0xdfb00000-0xdfbfffff]
[ 0.668404] pci 0000:00:1c.1: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 0.668413] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 0.668417] pci 0000:00:1e.0: bridge window [io 0xc000-0xcfff]
[ 0.668424] pci 0000:00:1e.0: bridge window [mem 0xdfa00000-0xdfafffff]
[ 0.668479] pci 0000:00:1e.0: setting latency timer to 64
[ 0.668486] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.668490] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.668494] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.668497] pci_bus 0000:01: resource 1 [mem 0xdfd00000-0xdfefffff]
[ 0.668501] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xcfffffff pref]
[ 0.668504] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 0.668508] pci_bus 0000:02: resource 1 [mem 0xdfc00000-0xdfcfffff]
[ 0.668511] pci_bus 0000:02: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[ 0.668515] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.668518] pci_bus 0000:03: resource 1 [mem 0xdfb00000-0xdfbfffff]
[ 0.668522] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 0.668525] pci_bus 0000:04: resource 0 [io 0xc000-0xcfff]
[ 0.668529] pci_bus 0000:04: resource 1 [mem 0xdfa00000-0xdfafffff]
[ 0.668532] pci_bus 0000:04: resource 4 [io 0x0000-0xffff]
[ 0.668536] pci_bus 0000:04: resource 5 [mem 0x00000000-0xffffffff]
[ 0.668659] NET: Registered protocol family 2
[ 0.668759] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.669035] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.669457] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.669745] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.669748] TCP: reno registered
[ 0.669753] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.669765] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.669956] NET: Registered protocol family 1
[ 0.670178] pci 0000:01:00.0: Boot video device
[ 0.670197] PCI: CLS 64 bytes, default 64
[ 0.670273] Unpacking initramfs...
[ 1.021328] Freeing initrd memory: 14268k freed
[ 1.029331] Simple Boot Flag at 0x7a set to 0x1
[ 1.030059] audit: initializing netlink socket (disabled)
[ 1.030079] type=2000 audit(1500512896.024:1): initialized
[ 1.042919] highmem bounce pool size: 64 pages
[ 1.042927] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 1.043269] VFS: Disk quotas dquot_6.5.2
[ 1.043313] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.043424] msgmni has been set to 1720
[ 1.043691] alg: No test for stdrng (krng)
[ 1.043745] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.043750] io scheduler noop registered
[ 1.043753] io scheduler deadline registered
[ 1.043783] io scheduler cfq registered (default)
[ 1.044163] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.044194] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.044197] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.044744] GHES: HEST is not enabled!
[ 1.044764] isapnp: Scanning for PnP cards...
[ 1.397961] isapnp: No Plug & Play device found
[ 1.398043] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.418440] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.439270] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.439627] Linux agpgart interface v0.103
[ 1.439877] i8042: PNP: PS/2 Controller [PNP0303:KBD] at 0x60,0x64 irq 1
[ 1.439881] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.440712] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.440900] mousedev: PS/2 mouse device common for all mice
[ 1.440970] rtc_cmos 00:05: RTC can wake from S4
[ 1.441129] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.441159] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.441305] TCP: cubic registered
[ 1.441393] NET: Registered protocol family 10
[ 1.441715] Mobile IPv6
[ 1.441720] NET: Registered protocol family 17
[ 1.441728] Registering the dns_resolver key type
[ 1.441793] Using IPI No-Shortcut mode
[ 1.441971] PM: Hibernation image not present or could not be loaded.
[ 1.441990] registered taskstats version 1
[ 1.442492] rtc_cmos 00:05: setting system clock to 2017-07-20 01:08:16 UTC (1500512896)
[ 1.442642] Freeing unused kernel memory: 416k freed
[ 1.442927] Write protecting the kernel text: 3496k
[ 1.442957] Write protecting the kernel read-only data: 984k
[ 1.462124] udevd[49]: starting version 175
[ 1.474745] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.502454] usbcore: registered new interface driver usbfs
[ 1.502503] usbcore: registered new interface driver hub
[ 1.507126] tg3.c:v3.123 (March 21, 2012)
[ 1.507340] usbcore: registered new device driver usb
[ 1.508250] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.508354] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.508362] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.508411] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.508463] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.523690] SCSI subsystem initialized
[ 1.528688] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.539422] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.539464] ehci_hcd 0000:00:1d.7: irq 21, io mem 0xffa80800
[ 1.548045] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.548136] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.548144] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.548150] usb usb1: Product: EHCI Host Controller
[ 1.548155] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.548161] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.548434] hub 1-0:1.0: USB hub found
[ 1.548447] hub 1-0:1.0: 8 ports detected
[ 1.548730] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.548739] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.548760] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.548801] uhci_hcd 0000:00:1d.0: irq 21, io base 0x0000ff80
[ 1.548887] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.548893] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.548899] usb usb2: Product: UHCI Host Controller
[ 1.548905] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.548910] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.549127] hub 2-0:1.0: USB hub found
[ 1.549141] hub 2-0:1.0: 2 ports detected
[ 1.549353] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.549363] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.549384] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.549449] uhci_hcd 0000:00:1d.1: irq 22, io base 0x0000ff60
[ 1.549531] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.549538] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.549544] usb usb3: Product: UHCI Host Controller
[ 1.549549] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.549555] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.549790] hub 3-0:1.0: USB hub found
[ 1.549803] hub 3-0:1.0: 2 ports detected
[ 1.550015] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.550025] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.550046] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.550108] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.550186] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.550193] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.550200] usb usb4: Product: UHCI Host Controller
[ 1.550205] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.550210] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.550451] hub 4-0:1.0: USB hub found
[ 1.550464] hub 4-0:1.0: 2 ports detected
[ 1.550655] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.550663] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.550682] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.550745] uhci_hcd 0000:00:1d.3: irq 23, io base 0x0000ff20
[ 1.550812] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.550818] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.550823] usb usb5: Product: UHCI Host Controller
[ 1.550829] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.550835] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.552192] hub 5-0:1.0: USB hub found
[ 1.552208] hub 5-0:1.0: 2 ports detected
[ 1.563198] tg3 0000:02:00.0: eth0: Tigon3 [partno(BCM95751) rev 4001] (PCI Express) MAC address 00:11:11:46:24:4a
[ 1.563210] tg3 0000:02:00.0: eth0: attached PHY is 5750 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 1.563218] tg3 0000:02:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.563225] tg3 0000:02:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.564695] libata version 3.00 loaded.
[ 1.566125] ahci 0000:00:1f.2: version 3.0
[ 1.566535] ahci 0000:00:1f.2: AHCI 0001.0000 32 slots 4 ports 1.5 Gbps 0xf impl SATA mode
[ 1.566544] ahci 0000:00:1f.2: flags: 64bit ncq pm led slum part
[ 1.566555] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.573610] scsi0 : ahci
[ 1.576222] scsi1 : ahci
[ 1.576619] scsi2 : ahci
[ 1.577449] scsi3 : ahci
[ 1.577580] ata1: SATA max UDMA/133 abar m1024@0xdffffc00 port 0xdffffd00 irq 20
[ 1.577588] ata2: SATA max UDMA/133 abar m1024@0xdffffc00 port 0xdffffd80 irq 20
[ 1.577595] ata3: SATA max UDMA/133 abar m1024@0xdffffc00 port 0xdffffe00 irq 20
[ 1.577601] ata4: SATA max UDMA/133 abar m1024@0xdffffc00 port 0xdffffe80 irq 20
[ 1.577671] ata_piix 0000:00:1f.1: version 2.13
[ 1.577763] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.578519] scsi4 : ata_piix
[ 1.580129] scsi5 : ata_piix
[ 1.580263] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.580272] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.581281] microcode: CPU0 sig=0xf34, pf=0x10, revision=0x17
[ 1.581871] ata6: port disabled--ignoring
[ 1.616468] firewire_ohci 0000:04:01.2: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[ 1.641046] microcode: CPU1 sig=0xf34, pf=0x10, revision=0x17
[ 1.645115] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.744558] ata5.01: ATAPI: PHILIPS DVD+/-RW DVD8631, CD21, max UDMA/33
[ 1.760471] ata5.01: configured for UDMA/33
[ 1.864032] usb 1-6: new high-speed USB device number 2 using ehci_hcd
[ 1.896038] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.896059] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.900034] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.900057] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.941911] ata1.00: ATA-7: ST3160812AS, 3.ADJ, max UDMA/133
[ 1.941916] ata1.00: 312500000 sectors, multi 8: LBA48 NCQ (depth 31/32)
[ 1.996772] usb 1-6: New USB device found, idVendor=0409, idProduct=0058
[ 1.996777] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.996780] usb 1-6: Product: USB2.0 Hub Controller
[ 1.996784] usb 1-6: Manufacturer: NEC Corporation
[ 1.997098] hub 1-6:1.0: USB hub found
[ 1.997153] hub 1-6:1.0: 4 ports detected
[ 2.000243] ata1.00: configured for UDMA/133
[ 2.000460] scsi 0:0:0:0: Direct-Access ATA ST3160812AS 3.AD PQ: 0 ANSI: 5
[ 2.002820] scsi 4:0:1:0: CD-ROM PHILIPS DVD+-RW DVD8631 CD21 PQ: 0 ANSI: 5
[ 2.015063] sd 0:0:0:0: [sda] 312500000 512-byte logical blocks: (160 GB/149 GiB)
[ 2.015226] sd 0:0:0:0: [sda] Write Protect is off
[ 2.015234] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.015297] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.028025] Refined TSC clocksource calibration: 3590.999 MHz.
[ 2.028035] Switching to clocksource tsc
[ 2.057851] sda: sda1 sda2 < sda5 >
[ 2.058510] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.061971] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.062064] sr 4:0:1:0: Attached scsi generic sg1 type 5
[ 2.062845] sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
[ 2.062854] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.063977] sr 4:0:1:0: Attached scsi CD-ROM sr0
[ 2.116165] firewire_core 0000:04:01.2: created device fw0: GUID 00023c041108272e, S400
[ 2.284156] usb 1-6.1: new low-speed USB device number 3 using ehci_hcd
[ 2.394901] usb 1-6.1: New USB device found, idVendor=413c, idProduct=3010
[ 2.394908] usb 1-6.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.402820] input: HID 413c:3010 as /devices/pci0000:00/0000:00:1d.7/usb1/1-6/1-6.1/1-6.1:1.0/input/input1
[ 2.403009] generic-usb 0003:413C:3010.0001: input,hidraw0: USB HID v1.00 Mouse [HID 413c:3010] on usb-0000:00:1d.7-6.1/input0
[ 2.403053] usbcore: registered new interface driver usbhid
[ 2.403058] usbhid: USB HID core driver
[ 2.480151] usb 1-6.3: new high-speed USB device number 4 using ehci_hcd
[ 2.598402] usb 1-6.3: config 1 interface 0 altsetting 0 has 7 endpoint descriptors, different from the interface descriptor's value: 5
[ 2.605522] usb 1-6.3: New USB device found, idVendor=148f, idProduct=5370
[ 2.605527] usb 1-6.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.605531] usb 1-6.3: Product: 802.11 n WLAN
[ 2.605534] usb 1-6.3: Manufacturer: Ralink
[ 2.605537] usb 1-6.3: SerialNumber: 1.0
[ 7.345744] PM: Starting manual resume from disk
[ 7.345750] PM: Hibernation image partition 8:5 present
[ 7.345753] PM: Looking for hibernation image.
[ 7.345977] PM: Image not found (code -22)
[ 7.345981] PM: Hibernation image not present or could not be loaded.
[ 7.401886] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.102098] udevd[339]: starting version 175
[ 9.404114] intel_rng: Firmware space is locked read-only. If you can't or
[ 9.404118] intel_rng: don't want to disable this in firmware setup, and if
[ 9.404121] intel_rng: you are certain that your system has a functional
[ 9.404124] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 9.435754] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 9.435764] ACPI: Power Button [VBTN]
[ 9.435859] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 9.435866] ACPI: Power Button [PWRF]
[ 9.524662] [drm] Initialized drm 1.1.0 20060810
[ 9.564055] [drm] radeon kernel modesetting enabled.
[ 9.564513] [drm] initializing kernel modesetting (R423 0x1002:0x5D57 0x1002:0x0302).
[ 9.564557] [drm] register mmio base: 0xDFDE0000
[ 9.564562] [drm] register mmio size: 65536
[ 9.564724] ATOM BIOS: R423XT
[ 9.564751] [drm] Generation 2 PCI interface, using max accessible memory
[ 9.564761] radeon 0000:01:00.0: VRAM: 256M 0x00000000C0000000 - 0x00000000CFFFFFFF (256M used)
[ 9.564768] radeon 0000:01:00.0: GTT: 512M 0x00000000A0000000 - 0x00000000BFFFFFFF
[ 9.565413] [drm] Detected VRAM RAM=256M, BAR=256M
[ 9.565419] [drm] RAM width 256bits DDR
[ 9.565524] [TTM] Zone kernel: Available graphics memory: 440766 kiB
[ 9.565530] [TTM] Zone highmem: Available graphics memory: 1033946 kiB
[ 9.565534] [TTM] Initializing pool allocator
[ 9.565573] [drm] radeon: 256M of VRAM memory ready
[ 9.565582] [drm] radeon: 512M of GTT memory ready.
[ 9.565619] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 9.566477] [drm] radeon: ib pool ready.
[ 9.568580] [drm] PCIE GART of 512M enabled (table at 0x00000000C0040000).
[ 9.568591] [drm] radeon: 4 quad pipes, 1 z pipes initialized.
[ 9.568627] radeon 0000:01:00.0: WB enabled
[ 9.568632] [drm] fence driver on ring 0 use gpu addr 0xa0000000 and cpu addr 0xff929000
[ 9.568638] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 9.568641] [drm] Driver supports precise vblank timestamp query.
[ 9.568673] [drm] radeon: irq initialized.
[ 9.568748] [drm] Loading R400 Microcode
[ 9.574547] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 9.584819] parport_pc 00:07: reported by Plug and Play ACPI
[ 9.584887] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 9.698429] iTCO_vendor_support: vendor-support=0
[ 9.740685] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 9.740838] iTCO_wdt: Found a ICH6 or ICH6R TCO device (Version=2, TCOBASE=0x0860)
[ 9.741286] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.955225] snd_intel8x0 0000:00:1e.2: setting latency timer to 64
[ 10.118928] [drm] radeon: ring at 0x00000000A0001000
[ 10.118954] [drm] ring test succeeded in 0 usecs
[ 10.119324] [drm] ib test succeeded in 0 usecs
[ 10.119782] [drm] Radeon Display Connectors
[ 10.119788] [drm] Connector 0:
[ 10.119792] [drm] VGA
[ 10.119798] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 10.119802] [drm] Encoders:
[ 10.119806] [drm] CRT1: INTERNAL_DAC1
[ 10.119811] [drm] Connector 1:
[ 10.119815] [drm] S-video
[ 10.119818] [drm] Encoders:
[ 10.119822] [drm] TV1: INTERNAL_DAC2
[ 10.119827] [drm] Connector 2:
[ 10.119831] [drm] DVI-I
[ 10.119835] [drm] HPD1
[ 10.119840] [drm] DDC: 0x68 0x68 0x68 0x68 0x68 0x68 0x68 0x68
[ 10.119846] [drm] Encoders:
[ 10.119850] [drm] CRT2: INTERNAL_DAC2
[ 10.119854] [drm] DFP1: INTERNAL_TMDS1
[ 10.119864] [drm] Possible lm63 thermal controller at 0x4c
[ 10.119940] [drm] radeon: power management initialized
[ 10.175123] [drm] fb mappable at 0xC00C0000
[ 10.175130] [drm] vram apper at 0xC0000000
[ 10.175135] [drm] size 7680000
[ 10.175139] [drm] fb depth is 24
[ 10.175144] [drm] pitch is 6400
[ 10.175264] fbcon: radeondrmfb (fb0) is primary device
[ 10.233619] Console: switching to colour frame buffer device 200x75
[ 10.240739] fb0: radeondrmfb frame buffer device
[ 10.240745] drm: registered panic notifier
[ 10.240763] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 10.251421] Installing spdif_bug patch: SB Audigy 2 ZS [SB0353]
[ 10.331559] intel8x0: white list rate for 1028:0177 is 48000
[ 11.071809] cfg80211: Calling CRDA to update world regulatory domain
[ 11.264157] usb 1-6.3: reset high-speed USB device number 4 using ehci_hcd
[ 11.471787] cfg80211: World regulatory domain updated:
[ 11.471793] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 11.471797] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 11.471801] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 11.471805] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 11.471808] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 11.471812] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 11.471815] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 11.471819] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 11.471823] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 11.538714] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 11.539182] Registered led device: rt2800usb-phy0::radio
[ 11.539227] Registered led device: rt2800usb-phy0::assoc
[ 11.539282] Registered led device: rt2800usb-phy0::quality
[ 11.539342] usbcore: registered new interface driver rt2800usb
[ 12.641091] Adding 4188156k swap on /dev/sda5. Priority:-1 extents:1 across:4188156k
[ 12.664614] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 12.882358] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.024521] loop: module loaded
[ 14.607930] RPC: Registered named UNIX socket transport module.
[ 14.607937] RPC: Registered udp transport module.
[ 14.607942] RPC: Registered tcp transport module.
[ 14.607946] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 14.655193] FS-Cache: Loaded
[ 14.689211] NFS: Registering the id_resolver key type
[ 14.689247] FS-Cache: Netfs 'nfs' registered for caching
[ 14.701127] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 16.922045] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input4
[ 17.555337] Bluetooth: Core ver 2.16
[ 17.555376] NET: Registered protocol family 31
[ 17.555382] Bluetooth: HCI device and connection manager initialized
[ 17.555388] Bluetooth: HCI socket layer initialized
[ 17.555393] Bluetooth: L2CAP socket layer initialized
[ 17.555406] Bluetooth: SCO socket layer initialized
[ 17.770182] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.770189] Bluetooth: BNEP filters: protocol multicast
[ 17.867181] Bluetooth: RFCOMM TTY layer initialized
[ 17.867194] Bluetooth: RFCOMM socket layer initialized
[ 17.867199] Bluetooth: RFCOMM ver 1.11
[ 18.729038] lp0: using parport0 (interrupt-driven).
[ 18.807331] ppdev: user-space parallel port driver
[ 20.427001] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.807237] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 23.416903] wlan0: authenticate with a0:63:91:75:5f:23
[ 23.445162] wlan0: send auth to a0:63:91:75:5f:23 (try 1/3)
[ 23.468309] wlan0: authenticated
[ 23.492035] wlan0: associate with a0:63:91:75:5f:23 (try 1/3)
[ 23.495799] wlan0: RX AssocResp from a0:63:91:75:5f:23 (capab=0x431 status=0 aid=1)
[ 23.522866] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 23.523235] wlan0: associated
[ 23.524421] cfg80211: Calling CRDA for country: DE
[ 23.534194] cfg80211: Regulatory domain changed to country: DE
[ 23.534202] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 23.534208] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 23.534213] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 23.534218] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 23.534223] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm)
[ 23.534229] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 34.216011] wlan0: no IPv6 routers present
[ 74.568272] I-pipe: head domain RTAI registered.
[ 74.568280] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 74.568347] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 74.568352] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 3591037000, CPU_FREQ 3591037000
[ 74.568356] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 74.568360] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 12413750
[ 74.617524] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 74.617573] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 74.617581] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 74.617586] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591037000 hz.
[ 74.617590] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 74.642837] RTAI[math]: loaded.
[ 77.486760] RTAI[math]: unloaded.
[ 77.489894] SCHED releases registered named ALIEN PEDV$D
[ 77.498452] RTAI[malloc]: unloaded.
[ 77.596024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 77.598940] I-pipe: head domain RTAI unregistered.
[ 77.599013] RTAI[hal]: unmounted.
9 years 3 months ago #96112 by skunkworks
(run linuxcnc from terminal and post the output)
Time to create page: 0.217 seconds
