Emco Compact 5 interface with linuxcnc (painless)
9 years 3 months ago #96113 by PCW
Debug file information:
./emco-lathe.hal:6: Can't find module 'probe_parport' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
linuxcnc.org/docs/html/getting-started/u....html#_parallel_port
9 years 3 months ago #96122 by Line680
stefan@debian:~$ linuxcnc
LINUXCNC - 2.7.0
Machine configuration directory is '/home/stefan/linuxcnc/configs/Half-fullstepMorph'
Machine configuration file is 'emco-lathe.ini'
Starting LinuxCNC...
emc/iotask/ioControl.cc 768: can't load tool table.
Found file(REL): ./emco-lathe.hal
LinuxCNC terminated with an error. You can find more information in the log:
/home/stefan/linuxcnc_debug.txt
and
/home/stefan/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
stefan@debian:~$
9 years 3 months ago #96146 by andypugh
Just delete the "loadrt probe_parport" from your HAL file.
9 years 3 months ago #96147 by Line680
Thank you all so much! :)
It worked just removing "loadrt probe_parport" as described! :)
Now i just need to learn the LinuxCNC program to start using the lathe. ;)
/Stefan
8 years 7 months ago #107008 by nateinaus
Thanks for doing all of this work for the Emco lathe, I found one buried and not functioning at my school and revived it. Works awesome!!
Cheers
5 years 1 month ago #220870 by Mixomax
Hello, i get the Half-fullstepMorph_MM configsĀ  and have troubles to threading whith my PC5, linuxcnc is waiting on the G33 comand, for velocity (o in linuxcnc statment but ok in the display) . in halmeter, the encoder ppr change statement thats ok, the encoder index as well, it seems the encoder index-enable don't change....
could you help me, i am not used to computer things, i learned a lot in few weeks but it looks like i am hurting a wall.
thanks you...
Time to create page: 0.066 seconds
