The pneumatics won't work right. Using the ATC interface I could sometimes get the platter to go down, but then the UP button did nothing. The platter would move inwards toward the spindle head (smacking into it if if wasn't high enough) but would not move back to its normal position. I did get the drawbar to work, both via the ATC interface in the software and with the front panel button, but now neither works. The only thing that works is platter indexing; it will rotate to proper tool number, but since the pneumatics don't work it just goes into error mode since the tool wasn't changed properly. I know all the pneumatic solenoids are working fine because I can trigger them with 24 VDC. I had to disassemble the ATC to get the XT into my garage and I might have reconnected air lines incorrectly, but I'm confident I have that straightened out now. But I've reset the ATC quite a few times now and I'm afraid I fouled everything up. Because now I can't get anything to do anything (with the exception of indexing the platter). Very frustrating.
