Troy,
With your machine serial number, Intelitek should be able to supply you with the 3 files I mentioned.
The Bench4K.ini file has all the machine operating parameters in it.
Items such as installed options, spindle configuration, servo tuning, etc.
Without that file, you're basically stuck.
The ATC.ini file has all the parameters for the ATC operation.
Items such as encoder count offset, toolchanger height, etc are in there.
You will need this file for ATC operation.
The compensation file is laser interferometer measured data that compensates for slight variations in the ballscrews.
Without that file, you will suffer slightly in accuracy.
That file will be accurate as long as the axis encoders have not been adjusted since the machine was shipped from the factory.
I have spoken with Intelitek and they should have those files for your specific machine.
I did not have your serial number, but their policy is to keep those files for each and every machine they made.
Give them a call and ask for the files.
