Light Machine Corp. Benchman XTr (retrofit)
9 years 2 months ago #98227 by x-Intelitek Engineer
Troy,
You will need to attack these errors one at a time.
Limits first, encoders next, then spindle.
Do you have the Benchman Manual?
If not, get it from:
www.intelitekdownloads.com/Manuals/CNC/O...ide_34-7713-0001.pdf
What is your spindle configuration (speed/toolchanger)?
What is the exact Nextmove card part number you have?
Don
9 years 2 months ago #98229 by x-Intelitek Engineer
Here is the Nextmove PC Manual in 2 parts
  • project-pegasus
  • New Member
  • New Member
9 years 2 months ago #98236 by project-pegasus
Replied by project-pegasus on topic Light Machine Corp. Benchman XTr (retrofit)
Thanks for those documents, Don. I can see in the Nextmove manual that the difference between the PNP and NPN cards is the placement of transistors on the card. I haven't been able to get in touch with anyone at Intelitek yet about the Nextmove card part number and unfortunately I don't see one on mine. But I should be able to setup the Benchman 4000 this weekend and see if I get the same problems I'm having with the XT. That would be a strong indicator that the card is the problem. The XT has the 45k spindle and the 12 tool ATC. I will probably be swapping the XT's 45k spindle with the 5k spindle from the 4000 so I can mill steel and aluminum. Thanks again for your help.
9 years 2 months ago #98305 by x-Intelitek Engineer
Since you supplied your own PC and Nextmove card, do you have the .ini files for your machines?
There is a Bench4K.ini and an ATC.ini that are both machine specific and without them, the software won't run.
There is a laser compensation file that is also machine specific.
Intelitek should have all 3 of these files in their records.
Don
  • project-pegasus
  • New Member
  • New Member
9 years 2 months ago #98314 by project-pegasus
Wow. Good to know. It asked for that disc when I was installing the software, but I assumed it was fine tuned pids for the machine that I could deal with later. What are the .ini files for exactly?
9 years 2 months ago #98317 by dynamyte24
Don, you mention .ini files being machine specific.
How is the correct machine determined?
I ask because my machine has Serial# 021-55AE-0184, but the program Serial# is 110-55AE-0176.
Rex
Time to create page: 0.228 seconds
