Emco PC turn 55 upgrade..
9 years 6 months ago #90768 by turbo
I have all of the f-errors set to .01mm now. Z backlash is .03 and the error had always shown up on the z. X is .016. I reposted the code I was running last night and I don't think I got any errors since then. I turned off "use high feedrate" in the cam, and it didn't change those moves to G0, but it did change them to a reasonable feedrate of 1mm/rev.
Does f-error have anything to do with how the machine follows the toolpath, or is it simply a limit that causes the machine to stop when exceeded?
9 years 6 months ago - 9 years 6 months ago #90779 by turbo
Replied by turbo on topic Emco PC turn 55 upgrade
You can hear the spindle chirping when it's trying to change speed to fast.
Last edit: 9 years 6 months ago by turbo.
9 years 6 months ago - 9 years 6 months ago #90932 by andypugh
turbo wrote: Does f-error have anything to do with how the machine follows the toolpath, or is it simply a limit that causes the machine to stop when exceeded?
It is just a limit that triggers an error. And I do rather suspect that the system might need the f-error limit to be > backlash magnitude.
Last edit: 9 years 6 months ago by andypugh.
9 years 6 months ago #91055 by turbo
Replied by turbo on topic Emco PC turn 55 upgrade..
jmelson wrote: No reason to use output from the VFD, the spindle encoder will be the most accurate.
Limiting spindle acceleration should be done by putting a lowpass or limit HAL component between motion.spindle-speed-out and whatever sends the analog voltage to the VFD.
Jon
Could you please elaborate on limiting the spindle accel?
9 years 6 months ago #91079 by andypugh
Replied by andypugh on topic Emco PC turn 55 upgrade..
turbo wrote: Could you please elaborate on limiting the spindle accel?
Typically that is a ramp-time setting in the VFD menus.
9 years 6 months ago #91685 by turbo
I don't think there is any way to access the VFD programming without an add on module or special programming. I'm pretty sure I'm going to have to do it in hal.
Time to create page: 0.133 seconds
