Why the enthusiasm for Modbus? Initially I would suggest running the VFD from an analogue voltage and fwd-rev commands.sspeed33317 wrote: Which brand VFD works best with Modbus for LInuxCNC ?? Or is it not a problem
to just as long as the drive is Modbus capable.
2.6. It is very close to release, and has a lot of fun new things (including remap).Which version of LInuxCNC should I be using ?
I have to do the M6 remap for the tool changer.
It shouldn't be hard.sspeed33317 wrote: OK, i will try to work on getting 2.6 running
Spindle set at orient speed, as it triggers the orient pin it goes into coast mode
when the pin drops into the detent there is a switch that lets the control know it
dropped and also commands a stop signal to the VFD, so until that pin raises
back out no matter what the VFD will not move the spindle, giving a spindle lock fault
If i can do that without using Modbus i'm all for it
