Okuma lathe conversion.
08 Oct 2015 16:55 #63564 by andypugh
Replied by andypugh on topic Okuma lathe conversion.
It would be much more satisfying to work out how to interface the original encoders.
However the combination of data / strobe / clock seems a bit unusual. It is possible that it is SPI, though, and I think I would try connecting to a Mesa BSPI channel to see what comes out.
Have you seen this?
s3.amazonaws.com/Icarus/DOCUMENTS/Okuma_Manuals_614.pdf
The following user(s) said Thank You: Henk
09 Oct 2015 05:43 #63592 by timewarp
Replied by timewarp on topic Okuma lathe conversion.
Thamks Andy, Yes I have that manual. I think figuring the encoders might be beyond my skill level. At this point I am going to look for replacement servos. I might already have some drives that could work. Just bought a 15hp vfd for the spindle.
11 Oct 2015 03:32 #63675 by cmorley
Replied by cmorley on topic Okuma lathe conversion.
You might try posting on the practical machinist forum - more people with okuma experience there.
Chris M
19 Oct 2015 23:03 #63957 by timewarp
Hi, I have been tearing into the lathe a bit, ordering parts and waiting on the mail. I have already won an auction on an opto22 board that now looks unusable!
(Dumbass!)
I took the encoder cover off the x axis and removed the encoder. The shaft is tapered and keyed with an m5 bolt holding the encoder shaft on. I then dismantled the encoder to the point where I have a 25mm shaft that I can bolt on to the motor shaft. So now I am looking for an encoder that I can use with the mesa boards I have ordered (5i25 7i77) that can slip over a 25mm shaft or directly on to the taper. There is about 18mm 0f tapered shaft , 18mm on the big end, 13.5 on the small end. 1:4 ??
I am looking for some help finding an encoder, can't seem to find one.
Thanks, Paul
Also, is this going to work for me?
www.ncix.com/detail/gigabyte-motherboard...-j1900-1a-109314.htm
Do most people mount computer in the cabinet behind the machine and run long cables to front lcd, switches , usb etc ? or is there a better option?
Thanks!
19 Oct 2015 23:11 #63959 by andypugh
If this is because the 5i25 does not have the 50-pin header that the other Mesa cards have, then possibly this would help, on your second 5i25 header.
store.mesanet.com/index.php?route=produc...74_80&product_id=285
But Mesa have IOP cards that duplicate the capabilitied of the Opto22 anyway.
Have you considered a belt-drive to an encoder with an integral shaft? Or connecting the encoders to the ballscrews rather than the motor?
You might actually want _both_ encoders, if possible. The commutation signals from the original encoder are likely to be useful (or essential) for driving the motors.
Do most people mount computer in the cabinet behind the machine and run long cables to front lcd, switches , usb etc ? or is there a better option?!
People seem to all find their own solution, but I would be more comfortable with long keyboard and mouse wires than long analogue signal cables.
The Mesa 7i73 can make connection of PC to control panel easy and neat.
20 Oct 2015 19:02 #63997 by timewarp
Thankyou Andy, i hadnt thought of belt drive, but i guess it is another option. Mesa stuff should be here soon so i will have to figure connections out with what i have.
Can't use the original encoder as it is now in pieces.
Any thoughts on the computer?
paul
20 Oct 2015 19:04 #63998 by andypugh
In that case you probably need to find an encoder with commutation tracks, and connect it directly to the motor.
(Is there no possibility of re-assembling the original encoder?)
21 Oct 2015 22:05 #64067 by timewarp
Thanks Andy, so now i am looking for 2 encoders with a hollow shaft of either 10mm, 25mm or tapered. With commutation. Absolute and differential right?
Went ahead and ordered the motherboard, i think it will be ok.
Paul
21 Oct 2015 22:11 #64068 by andypugh
This might be worth reading:
www.cui.com/product/resource/amt303-series-comm-encoders.pdf
You might end up having to make an adaptor for the tapered shaft.
21 Oct 2015 23:57 #64084 by timewarp
Thanks Andy, I had looked at those encoders, I thinks I will order one and see if I can adapt it to a 10mm shaft. am I going to need the demo board?
Paul
Time to create page: 0.163 seconds
