Okuma lathe conversion.
22 Oct 2015 00:00 #64085
Replied by andypugh on topic Okuma lathe conversion.
You might need the demo board to program them. I am not sure.
Which drives are you going to use?
- timewarp
22 Oct 2015 00:44 #64092
by timewarp
Replied by timewarp on topic Okuma lathe conversion.
I have not figured out what I am going to use for drives. I have some vfd drives from emerson/control technologies that might work but i would need a card to put in them I think. I also have been looking at amc as they seem cheap and popular.
22 Oct 2015 00:53 #64094
I assume that your motors are brushless? In that case most types of VFD won't work (CT Unidrive will, with the right setup, if that is what you have).
AMC drives with hall-sensor inputs will work with the commutation encoders.
You _can_ commutate with a normal encoder with software in LinuxCNC, but I don't really like to recommend it for an axis.
If you get the commutation sensors aligned correctly then the Mesa 8i20 with software commutation is an option.
What is the power and voltage rating of the motors?
- timewarp
22 Oct 2015 01:06 #64097
by timewarp
I picked up 3 unidrive 1402's here locally, but don't have the servo card with them, some modbus card?
There is a photo of one of the servo nameplates on page 1, other axis motor is 2kw i think.
22 Oct 2015 01:40 #64100
If you can find a servo card then those are very good drives, so I would be tempted to use them.
Ask CT what you need to run your servos.
Otherwise, the Mesa 8i20 can handle 2.2kW @ 300V or so.
The Pico drives are rated 20A / 160V and may also be an option: www.pico-systems.com/acservo.html (depending on voltage)
AMC would be a good choice if the price was right.
One other (rather eccentric) option might be to fit Resolvers. Resolvers are great and can be used for commutation, and there are some on eBay with a nice big hole.
www.ebay.com/itm/New-Tamagawa-BRX-Smarts...4:g:CowAAOxyXTRR~Iy7
www.tamagawa-seiki.com/pdf/download/1507n15ej.pdf
(12.7mm bore)
The CUI encoder documents mentioned that resolvers are excellent but very expensive, those on eBay probably list at $500 normally.
(12.7mm bore)
- timewarp
23 Oct 2015 12:59 #64169
by timewarp
Hi Andy, Can you please have a look at this document and tell me which encoder output signal I should pick (page 3)
I am thinking 312c or 312d?
media.digikey.com/pdf/Data%20Sheets/CUI%...nds%20PDFs/AMT31.pdf
Thanks, Paul
Thanks, Paul
23 Oct 2015 15:37 - 23 Oct 2015 15:37 #64170
That is going to depend on what goes at the other end of the encoder. So, you need to look at the requirements of the encoder counting hardware and the motor drive (if the commutation signals are being wired direct to the drive)
media.digikey.com/pdf/Data%20Sheets/CUI%...ds%20PDFs/AMT31.pdfl
Last edit: 23 Oct 2015 15:37 by andypugh.
- timewarp
23 Oct 2015 22:28 #64184
by timewarp
If I can get the amt encoder to play with the 8i20 drive I will go that route I think.
As an aside, How do the tamagawa resolvers mount to the shaft?
Paul
Paul
24 Oct 2015 00:10 #64189
When I recently removed the encoder from a motor to fit a resolver I used the second approach, but I was already machining the motor shaft to shorten the motor.
That should be fairly straightforward.If I can get the amt encoder to play with the 8i20 drive I will go that route I think.
Some have a small setscrew (page 12) or you clamp them against a shoulder (page 11) with an axial screw.As an aside, How do the tamagawa resolvers mount to the shaft?
Time to create page: 0.177 seconds
