- Thank you received: 2181
Okuma lathe conversion.
Chris M
- timewarp
(Dumbass!)
I took the encoder cover off the x axis and removed the encoder. The shaft is tapered and keyed with an m5 bolt holding the encoder shaft on. I then dismantled the encoder to the point where I have a 25mm shaft that I can bolt on to the motor shaft. So now I am looking for an encoder that I can use with the mesa boards I have ordered (5i25 7i77) that can slip over a 25mm shaft or directly on to the taper. There is about 18mm 0f tapered shaft , 18mm on the big end, 13.5 on the small end. 1:4 ??
I am looking for some help finding an encoder, can't seem to find one.
Thanks, Paul
Also, is this going to work for me?
www.ncix.com/detail/gigabyte-motherboard...-j1900-1a-109314.htm
Do most people mount computer in the cabinet behind the machine and run long cables to front lcd, switches , usb etc ? or is there a better option?
Thanks!
If this is because the 5i25 does not have the 50-pin header that the other Mesa cards have, then possibly this would help, on your second 5i25 header.timewarp wrote: Hi, I have been tearing into the lathe a bit, ordering parts and waiting on the mail. I have already won an auction on an opto22 board that now looks unusable!
store.mesanet.com/index.php?route=produc...74_80&product_id=285
But Mesa have IOP cards that duplicate the capabilitied of the Opto22 anyway.
Have you considered a belt-drive to an encoder with an integral shaft? Or connecting the encoders to the ballscrews rather than the motor?I am looking for some help finding an encoder, can't seem to find one.
You might actually want _both_ encoders, if possible. The commutation signals from the original encoder are likely to be useful (or essential) for driving the motors.
People seem to all find their own solution, but I would be more comfortable with long keyboard and mouse wires than long analogue signal cables.Do most people mount computer in the cabinet behind the machine and run long cables to front lcd, switches , usb etc ? or is there a better option?!
The Mesa 7i73 can make connection of PC to control panel easy and neat.
- timewarp
Can't use the original encoder as it is now in pieces.
Any thoughts on the computer?
paul
timewarp wrote: Can't use the original encoder as it is now in pieces.
In that case you probably need to find an encoder with commutation tracks, and connect it directly to the motor.
(Is there no possibility of re-assembling the original encoder?)
- timewarp
Went ahead and ordered the motherboard, i think it will be ok.
Paul
