Servo driver selection
- Gatesy
07 Dec 2015 02:05 #66537
by Gatesy
Replied by Gatesy on topic Servo driver selection
Ah, I see what you mean about the Granite drives. Well if the IONI drives servos in all 3 modes then that brings that back into my choices. As it seems this will control the servo in all modes and output all waveforms to the servo as well
I will have to check the number written on the encoder cover. I'm quite happy to change them as like I mentioned previously I'd quite like to get away from Fanuc specific parts and use generic parts as much as possible
They certainly are small, only a small mill though. Will certainly give the PICO products some consideration, thanks
07 Dec 2015 16:57 #66560
The Fanuc encoders are unlikely to go wrong, and they are also likely to be very high quality.
Replied by andypugh on topic Servo driver selection
- Gatesy
07 Dec 2015 19:24 #66572
by Gatesy
The granite IONI drives seem to be able to provide the greatest variety of waveforms and control modes.
Is there any advantage in using velocity control mode over torque mode?
Seeing as using a dumb drive creates a proper feedback through the control and PC, are there any advantages or disadvantages in using a smart servo drive?
07 Dec 2015 19:37 #66574
The velocity feedback loop in the drive might run faster than the LinuxCNC feedback loop, and so give better velocity control.
The drawback is that you often need a Windows-only separate application to tune the drive, which is relatively inconvenient.
I don't know if the IONI drives have a dedicated mode for the Fanuc commutation signals. It seems a logical thing for them to offer.
If not, then the Pico system might be preferable.
- Gatesy
07 Dec 2015 20:09 #66576
by Gatesy
The Granity software configuration tool is available as both windows and Linux versions
Cascaded control loops (PIV):
Torque / current control, update frequency 20.0 kHz
Velocity control, update frequency 2.5 kHz
Position control, update frequency 2.5 kHz
I have contacted Granite and need to let them know what my encoders are..
The numbers on the encoder casings are A860-0308-T112 And they are 2500P
- Gatesy
07 Dec 2015 20:17 #66577
by Gatesy
Apparently this an incremental encoder
07 Dec 2015 20:18 #66578
With the 4 commutation tracks?
- Gatesy
07 Dec 2015 22:57 #66591
by Gatesy
I did have a look inside one a while, and I seem to remember it was like a glass disc with 4 tracks etched on to it?????
I'll have to check tomorrow to be sure
07 Dec 2015 23:02 #66592
That sounds like the 4-track gray-code, as has been discussed.
- Gatesy
07 Dec 2015 23:45 #66593
by Gatesy
Do these encoders give out a standard encoder output, or is it unique to Fanuc?
Time to create page: 0.160 seconds
